    Exporting with a transparent background
    6 Posts 5 Posters 2.2k Views 5 Watching
    • Z
      zaknbou
      well i need to have an animation with a transparent background to use later on with sony vegas ...
      how can i get rid off the background ? i could export as png sequence but the alpha channel is not there ?
      why ? any info guys ? is there another way to export with a transparent background ?
      • jcdbJ
        jcdb
        Edit your style and turn off sky and ground.
        http://www.acustombuilder.com
        • GaieusG
          There is no native way to export SU animation with alpha channel. You can set your background image to something you can edit out later (green or even magenta is often used for this)
          Also you could export your model to Kerkythea as there is a clipmap rendering preset and render your animation from there. Certainly this means learning another program as well as quite a long rendering time - but at least you'd have a better result.
            sorgesu
            I believe you can do this in the MAC. I'm not sure if Al Hart's RP tools does this currently. I think it may, but at any rate his NPR tools plug in will
            Susan Sorger
            Former Seller Hand Rendered Entourage
            Former Canadian Authorized Training Centre, SketchUp
              jstahlman
              On animation export, you can check transparency, but the result is a black background even with sky and ground unchecked in styles. Is this a bug? I want to pull small animated 3D videos into Flash, but I need transparency so I can put them on top of other objects.
              • GaieusG
                If the Mac can do it (which I now kind of remember),you will need to export your animation as a series of png (or tiff) files which support transparency rather than a *.mov file and use the images in your flash app.
                Still I'm not sure it could be done with an animation even on the Mac but good luck!
