<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Exporting with a transparent background]]></title><description><![CDATA[<p dir="auto">well i need to have an animation with a transparent background to use later on with sony vegas ...<br />
how can i get rid off the background ? i could export as png sequence but the alpha channel is not there ?<br />
why ? any info guys ? is there another way to export with a transparent background ?</p>
]]></description><link>https://community.sketchucation.com/topic/105913/exporting-with-a-transparent-background</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 12:28:30 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/105913.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 Aug 2008 15:05:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Exporting with a transparent background on Tue, 23 Dec 2008 08:53:01 GMT]]></title><description><![CDATA[<p dir="auto">If the Mac can do it (which I now kind of remember),you will need to export your animation as a series of png (or tiff) files which support transparency rather than a *.mov file and use the images in your flash app.</p>
<p dir="auto">Still I'm not sure it could be done with an animation even on the Mac but good luck!</p>
]]></description><link>https://community.sketchucation.com/post/1054773</link><guid isPermaLink="true">https://community.sketchucation.com/post/1054773</guid><dc:creator><![CDATA[Gaieus]]></dc:creator><pubDate>Tue, 23 Dec 2008 08:53:01 GMT</pubDate></item><item><title><![CDATA[Reply to Exporting with a transparent background on Mon, 22 Dec 2008 20:14:06 GMT]]></title><description><![CDATA[<p dir="auto">On animation export, you can check transparency, but the result is a black background even with sky and ground unchecked in styles. Is this a bug? I want to pull small animated 3D videos into Flash, but I need transparency so I can put them on top of other objects.</p>
]]></description><link>https://community.sketchucation.com/post/1054676</link><guid isPermaLink="true">https://community.sketchucation.com/post/1054676</guid><dc:creator><![CDATA[jstahlman]]></dc:creator><pubDate>Mon, 22 Dec 2008 20:14:06 GMT</pubDate></item><item><title><![CDATA[Reply to Exporting with a transparent background on Sat, 09 Aug 2008 21:15:44 GMT]]></title><description><![CDATA[<p dir="auto">I believe you can do this in the MAC.  I'm not sure if Al Hart's RP tools does this currently.  I think it may, but at any rate his NPR tools plug in will</p>
]]></description><link>https://community.sketchucation.com/post/1026023</link><guid isPermaLink="true">https://community.sketchucation.com/post/1026023</guid><dc:creator><![CDATA[sorgesu]]></dc:creator><pubDate>Sat, 09 Aug 2008 21:15:44 GMT</pubDate></item><item><title><![CDATA[Reply to Exporting with a transparent background on Sat, 09 Aug 2008 15:31:00 GMT]]></title><description><![CDATA[<p dir="auto">There is no native way to export SU animation with alpha channel. You can set your background image to something you can edit out later (green or even magenta is often used for this)</p>
<p dir="auto">Also you could export your model to Kerkythea as there is a clipmap rendering preset and render your animation from there. Certainly this means learning another program as well as quite a long rendering time - but at least you'd have a better result.</p>
]]></description><link>https://community.sketchucation.com/post/1025966</link><guid isPermaLink="true">https://community.sketchucation.com/post/1025966</guid><dc:creator><![CDATA[Gaieus]]></dc:creator><pubDate>Sat, 09 Aug 2008 15:31:00 GMT</pubDate></item><item><title><![CDATA[Reply to Exporting with a transparent background on Sat, 09 Aug 2008 15:19:09 GMT]]></title><description><![CDATA[<p dir="auto">Edit your style and turn off sky and ground.</p>
]]></description><link>https://community.sketchucation.com/post/1025960</link><guid isPermaLink="true">https://community.sketchucation.com/post/1025960</guid><dc:creator><![CDATA[jcdb]]></dc:creator><pubDate>Sat, 09 Aug 2008 15:19:09 GMT</pubDate></item></channel></rss>
