    Big File Sizes/ High Poly
    39 Posts 20 Posters 8.3k Views 20 Watching
    • K
      kwistenbiebel
      Yep, those 'profile' things suck. Never used them either.
      • P
        pmiller
        Profiles are essential for new users -- allowing newbies to tell easily when they are not making faces and helping to distinguish groups and components.
        • Chris FullmerC
          That is very true Paul. I'm glad you mentioned that. I still leave them for that reason, I though I generally turn them off when I render an image.
          The reason they are there, as it was explained to me, is because often we perceive depth this way in real life. Items that have space behind them appear to have a more bold outline or a harder edge around them. I don't know that the profile edges accomplished that very successfully, but that was what I was told.
          • K
            kobus
            in the basecamp tutorial section there's a tip for this.
            The essence is that you can make scenes without camera positions.
            This way the scene tab behaves like a display mode.
            Per tab you retain full control over displayed layers and such, as mentioned by earlier posts.
            Good luck !
            you should be interested in the future. you will spend the rest of your life there
            • Chris FullmerC
              Ah yes, thats a great one! I highly recommend it
              • GaieusG
                I wonder who gave that presentation. πŸ˜‰ It was a really good one by the way πŸ‘
                • david_hD
                  david_h
                  Good luck !
                  That is excellent. I do that a lot my self. One thing I never use is profiles or jitters. What the heck for? In fact I rarely use "styles" at all, and certainly never when modeling. navigating in Wire mode is always good. Thanks for the tips as well.
                  I feel like such a noob when I come on this site. πŸ’š
                  • Chris FullmerC
                    ahh, you're too nice Gaieus! I saw your portion was also referred to yesterday here on the forum. I think the tips and tricks session was the best! πŸ˜„ Though I AM biased....
                    • GaieusG
                      Too bad we had such short times each. I had about ten of them and finally I turned out to pick the two that were the least "spectacular". (Not to speak about running into a couple of bugs which I could've avoided) 😳
                      • RichardR
                        Richard
                        Good luck !
                        I use scenes a lot to manage layers. I actually use then to turn layers off and wireframe the view in large models to assist in navigating then shortcut or next scene tab to turn back on. for Camera views when exporting to render I actaully use two scenes - the first to set camera location and the second to set all layers on!
                        Another trick I use a lot with very large models say where I am adjust plant layout in a specific location or when working ob heavy geometry is to drag select any items or geometry where i want to work in detail shortcut to group, double click to edit this new group and hide rest of model, I then after editing explode that newly made group! I would say this is possibly one of my mostly used workflows to speed up modelling! Though shortcuts are essential to speeding this, but aren't they essential for all modelling anyway!
                        It was interesting some years ago a long time SU user suggested to me that trying to remember shortcuts to save seconds a day was a waste of effort. I would have to say good workflow using shortcuts could save as much as 5-6 hours in 8 hours of modelling!
                        BUILTBRAND.COM.AU
                        • plot-parisP
                          plot-paris
                          I totally agree with you on that Richard. it saves a tremendous amount of time. and your model gets even tidyer, because it is no effort to press a button to create a group/component (and for that matter press another button to explode it again πŸ˜‰ )
                          modelhead, could you give me some clues of what you simplify in the components to reduce file size to this amount? could you perhaps post a before-after example? that would help me a lot to see if I am on the right way.
                          if you are good with a program you tend to stick to your habits very easily. but sometimes it is good to question them again and maybe improve them to get an even faster workflow.
                          • david_hD
                            david_h
                            i stuggle with this as well. I do a lot of site modeling that requires trees and I like to use 2D cllips as often possible, but for aerial views, I kinda need 3D trees, and the good ones are so High poly. I guess I should play around with Proxies more to simplify and only turn on the biggies when it comes time to render or something, but Any other hints to manage the file would be grateful.
                            Ps. I havne't done it yet, but I have the link to the 3D basecamp workshop on this. I oughtta listen to it. . ..
                            I wasn't invited, you know. . . 😞
                            • 2 / 2
