    SketchUp and Rubies on Linux (yes, it works)
    71 Posts 27 Posters 46.3k Views 27 Watching
    • L
      lewiswadsworth
      @michelinux said:
      If you have a 64bit CPU (Intel or AMD, ubuntu 64 is for both) you can experience clear performance improvement from system boot speed to every application, particularly with applications that require a lot of RAM. Moreover it has been resolved the problem with non-64bit applications like adobe flash player and openoffice.
      The space, but the time in order to test a system does not lack me, but I can test it to my friend's pc.
      ciao
      Mick
      Mick, I did test SU Pro on Ubuntu 8.04 AMD64 (on a computer where I also have it running on both XP and Ubuntu 32bit), and I was able to get the same range of image sizes for both PNG and JPEG exports as I can on Windows...an easy 4000 pixel max dimension. And (possibly because of an update recently to WINE) SU no longer required the Registry changes noted above to work immediately after install...it opened with some empty TOD, Instructor, and Learning Center windows, but these no longer aborted the program start.
      However, it does seem like SU might be a little more likely to hang on Ubuntu 64. Launching Firefox at the same time as SU was open caused the SU window contents to disappear and the app to freeze at one point, although I haven't been able to duplicate that problem and it has been working since.
      Incidentally, the newest update to WINE (they claim) should allow one to run a wider range of Windows graphical applications, most notably Photoshop CS3. That's pretty amazing...I'll have to test it.
      --Lewis
      col sporcar si trova
      • L
        linea
        There is talk of developing a free CS3 type app for linux, probably a derivative of gimp, inkscape etc.
        • L
          lewiswadsworth
          I'm aware of that. It will be hard to catch up though. I use GIMP for a few things, and it has about the full functionality of PS 4.0, plus a few unusual capabilities if you download the plugins for animation. But with no smart objects, no adjustment layers, and no 3D, it's going to be a long haul to achieve PS CS3 XT equivalency. Krita has adjustment layers, but seemed to have other issues last time I checked...and I can't forever be checking to see if anyone has "caught up." It's always a catch-up game with Open-Source, and with few exceptions (at least in my areas of interest, mainly graphics) there's very little that's truly innovative.
          That's not always bad, of course. It could be argued that even the GNOME desktop (which is what non-coders really find so compelling about Ubuntu, and often mistake forLinux) in so many of these OS is functionally equivalent to the old, no-frills pre-OS-X Apple desktop. KDE has attempted some innovation, on the other hand, but I'm not sure anyone really wants more elaborate desktop managers. Do we really need things like Compiz to be productive, anyway?
          What actually led me to investigate the whole topic of SU on Linux was the complexity and increasing productivity-restriction of the two main commercial OS, Mac and Vista/Windows 7. I want a bolt-hole when Windows XP finally becomes unusable on modern hardware...open-source versus commercial software development is utterly irrelevant in my particular circumstances.
          • L
            linea
            I kind of agree. I've got my old laptop up and running ubuntu now. It is a lean go anywhere machine(does't matter if I drop it) running free apps that can't do everything but at least give me a useable tool while I'm out about. Trying to get SU installed too, I'll let you know 😄
            As for a CS3 clone, I would imagine that Adobe's copyright clauses make it impossible to come anywhere close, but it'll be interesting to see what an open source attempt can create.
            Jon
            • L
              lewiswadsworth
              More SU on WINE on Ubuntu 64-bit notes:
              I installed this again yesterday (had to wipe a partition...turns out that having 64bit and 32bit versions of Ubuntu on the same drive can be problematic) and tried to do some actual project work with SU once I had it going.
              With another couple of minor WINE updates, SU now installs with no differences from the Windows installation process, as long as one allows WINE to install Gecko so that it can render HTML (used in the SU TOD window, for instance). Layout still doesn't work at all, although you must allow the Installer to pointlessly download .NET before it will continue with SU's installation.
              There is a noticeable problem, once SU file sizes get a little bigger in this system: certain visual operations don't immediately appear on the screen. For instance, a zoom extents operation does not complete (or perhaps the window simply doesn't redraw) until one clicks somewhere in SU and begins another operation; the same sort of thing happens with hiding/unhiding objects. This can get a little tedious when editing groups and components...it is difficult to know, until you start another operation, whether a component/group is open for editing or not.
              Also, 2D exports to DWG format failed about 50% of the time with a Bugsplat, although when they did work they were completed in about half the time it takes on Windows XP. Graphic exports to PNG and JPG complete much, much faster than they do on Windows...almost instantaneous with large resolutions (3000-4000 pixels) and shadows/anti-aliasing on.
              • E
                eter
                Thanks to this thread I'm now running SketchUp on my Ubuntu partition. That Windows partition is suddenly looking a little superfluous. 😄
                Thanks for the instructions, although as Lewis observed, this is becoming more and more straightforward with newer releases of WINE.
                • L
                  lewiswadsworth
                  ?eter, are you experiencing the lag in hiding/showing/zooming that I noted in my previous post? It's only slightly annoying (much less annoying than trying to get dual monitors to run on Ubuntu), but I'm curious to know if anyone else has had the problem or had it and done something about it.
                  • E
                    eter
                    No trouble in zooming/hiding/showing that I've noticed yet, although I haven't worked on a really complex model. I'm running the 32 bit version because my home pachine is a P4. The one problem I did notice was that the tool windows wouldn't dock to each other when I moved them together-in fact they behaved pretty strangely all round- not collapsing when you clikc the title bar etc. But it certainly seems functional so far.
                    • L
                      lewiswadsworth
                      The toolbar problem seems to turn up on both 32-bit and 64-bit versions of Ubuntu. It would be interesting to know if it exists on WINE on other distros.
                        Scienthsine
                        If other people don't have a problem with the view not refreshing from some things, then it's probley your video drivers... which is likely considering the shape the nvidia and ati drivers for linux are in atm.
                        However, this might be easily fixable. It sounds to me like it just doesn't refresh in some places where it should, and so you get no change until an action forces a refresh. It's unlikely that the operation is actually waiting, although I guess this could be possible if the events are somehow getting sent to sketchup late... but I don't think this is it.
                        So, we just need to try to force the view to refresh. Maybe one or a few of the observer classes can watch for changes, and invalidate the view? As a last resort we could launch a non-modal web dialog thing and have a javascript timeout that invalidates the view... but I think this would mean that we couldn't use another script with web-dialogs... right? (Haven't used one in my scripts yet, and haven't used anyone elses scripts either... but I assume that you can only have one running at a time?)
                        I might attempt to install via wine tonight, as I actually just reinstalled windows on a 10 gig drive a few weeks ago for sketchup... it's the only thing I boot windows for. (Well and starcraft... but if I can run sketchup under wine, I'll bite the bullet and run starcraft in wine also.)
                        [Edit] Also it could be wine in combination with a driver... anyway, we need to report it to wine and if it's not their problem, report it to your video driver people.
                          mozzie
                          Another data point.
                          I understand that the SU install works for some NVidia graphics cards, but not for others?
                          Anyway, I thought I'd give it a go. I run SU on a WinXp laptop that's in hospital.
                          My other system is a Shuttle m/b with integrated/on-board Intel graphics chip (82865G Integrated Graphics Controller), Mandriva 2008.1, & Samsung 940bw monitor at 1440 x 900 - 24bpp.
                          X driver (Intel 810 and above),
                          Wine 1.1.2. I haven done any MS registration tho'.
                          SU Pro (licensed) installs successfully after making the registry changes and Gecko.
                          Icon appears on desktop. Launches fine EXCEPT the window is black - menus are fine and appear to work. If I draw lines/rectangles (even though I can't see them) SU appears to have done them, as it then wants to save on exit. So it appears to be a screen drawing problem?
                          Any suggestions?
                          • L
                            lewiswadsworth
                            That's the integrated graphics controller, I'm afraid. Bad or no OpenGL implementation on Linux. Sorry...it's the same result I get on an ATI graphics card on a Dell XPS notebook. But NVidia 7 and 8 series GeForces seem to work pretty well with this and later versions of WINE.
                            Sci,
                            Do I understand you...you are proposing a ruby script for forcing a redraw, called every few seconds or automatically at the end of certain commands? I suppose first step would be to know exactly what events are not followed by refreshes, and then find the classes that observe them.
                              Scienthsine
                              Yep, exactly, it's hacky... but desperate times 😉
                              That would be good, I have alot to do this weekend, so I haven't installed it on my linux drive yet... but I don't expect to have the same problem, having a radeon. We'll see...
                              • L
                                lewiswadsworth
                                I have yet to be able to get SU to work on WINE with a Radeon at all...it rarely even works well on Windows, after all, with ATI cards, and the tech support people in Boulder will confirm that. Please let me know if you figure it out.
                                  mozzie
                                  OK - have it working with my 82865G Integrated Graphics Controller. In the WINE forums, there was a suggestion that there was an issue with the Intel and ATI OpenGL drivers under DRI and that turning it off would work.
                                  Requires a mod to the xorg.conf file - add the following line under the
                                  Section "Device"
                                  Option "DRI" "False"
                                  EndSection
                                  And I now have a non-black screen, and visible drawings. Not tested comprehensively, but will report back.
                                  • L
                                    lewiswadsworth
                                    Mozzie, I'll have to try that as well on the Dell notebook...could you provide a link to the relevant WINE forum threads? Thanks.
                                    EDIT: It worked! ...on a Dell Inspiron XPS P4 3.40 GHz with some nameless ATI Radeon with 256 MB VRam, about four years old. There is a strange white box around the cursor, but otherwise SU looks normal...I won't have a chance to test this with real drawings for a few days, though. (Incidentally, this computer had bad ATI/OpenGL issues running SU on Windows...I've always considered it a piece of junk.)
                                    The toolbar problem seems to be caused by allowing the Window Manager "to control the window" in the Configure WINE control panel. However, unchecking the option can cause worse issues...on my systems, it seems that toolbars that are not docked or pallet windows (like Materials) that were open prior to the WINE configuration change will vanish until the desktop manager is allowed to manage SU again.
                                      mozzie
                                      You probably don't need it now ... but here's the WineHQ reference.
                                      It's the second item in the list, the heading is "Black Screen".
                                      http://appdb.winehq.org/commentview.php?iAppId=1815&iVersionId=6842
                                      The interesting comment there is the last item in the black screen thread.
                                      RE: Black Screen
                                      by Alexander Sabourenkov on Thursday August 7th 2008, 1:21
                                      Ok.
                                      I'll try to track down the source of the problem. Seems likely that it is something missing from both intel and ati open source drivers, but present in non-accelerated driver and proprietary ones (nvidia at least).
                                      I did a little testing. I don't have the white box problem (cursor looks normal).
                                      Onscreen operations seem Ok, but horribly slow (to be expected) as the hardware acceleration is compromised.
                                      Export to 2D graphic (PNG) was unsuccessful.
                                      • L
                                        lewiswadsworth
                                        Thanks, Mozzie. I also could not export to PNG on the old Dell notebook, although JPG worked well. And of course, I lost functionality on other native apps that depended on DRI, like certain screensavers and some of the eyecandy on the Amarok music player.
                                        In the end, it's not worth doing on this particular aging notebook computer...with a fairly big model (which will run just fine on WINE on a computer with an 8-series GeForce), turning on textures and shadows in SU nearly froze the system. And even once I managed to force SU/WINE to quit, the computer was hopelessly sluggish until I restarted it. Oh well. I'm sure on a more modern system with ATI or integrated graphics this will be of great value. But it seems like the NVidia cards are still the best bet for a system to run SU on Wine on Linux without too much functionality loss, assuming one has the option...at least until the poster you quote tracks down the problem.
                                        • E
                                          eter
                                          OK, I was playing around a bit this week and I DO get the display delay thing- specifically, if I reverse a face, it doesn't display as reversed until I try another operation. I'm using an nVidia 6200 with the proprietary drivers that Ubuntu 7.04 installs.
                                          • T
                                            tomasz
                                            I have managed to start SU Free on SuSE 11.0 with Wine 1.1.4.
                                            I've got GeForce 6200. It works fine, almost as fast as on Windows 😄
                                            but.. every time I minimize SU window and then open it back I get BugSplat..
                                            SU(Wine) also doesn't refresh the view after selecting a scene. I have to click on the screen to see it changed.
                                            I was really surprised to see SU widow on Linux and to rotate quite complicated models without a problem!
                                            Tomasz
                                            • 2 / 4
