    Portfolio help
    18 Posts 7 Posters 972 Views 7 Watching
      remus
      Ok guys, im putting together a portfolio and need your opinions of the following images. All crits+comments gladly accepted, please dont hold back πŸ‘ Oh, and its probably worth bearing in mind that the portfolio is meant to highlight my artistic abilities (if any.)
      http://farm3.static.flickr.com/2063/2439737751_dd446905e7_o.png
      http://farm3.static.flickr.com/2418/2498029158_109c319181_o.png
      http://farm3.static.flickr.com/2094/2521285727_beb9a56ca1_o.png
      http://farm4.static.flickr.com/3269/2687577961_4b30676ff8_o.png
      http://farm4.static.flickr.com/3220/2453681057_64aaa49980_o.png
      http://farm4.static.flickr.com/3114/2704263326_e03f807792_b.jpg
      Thanks πŸ˜„
        marcosrodrigues
        all images are from SU? i like the first and the last. btw i think that for a portifolio the focus must go besides the 'artistic abilities'. maybe more specific: illustration, renderings, models...
        • how did you do the last model?
        | menos Γ© mais
          remus
          They were all modeled in SU then rendered in indigo. I just mentioned the 'artistic ability' it as thats what i was told i should try and show πŸ˜‰
          The last one was done by first modelling a big flat grid, then morphing it using cphilps' sketchyFFD script to bend it. I then intersected it with a flat plane, took quite a while but the result isnt too bad.
          • brodieB Offline
            brodie
            Those are all some really good images. A few things I noticed to consider
            The chair image seems a bit grainy. Maybe it's just the fabric texture, I can't tell.
            I really like the prison cell sort of image a lot. Great texture on the wall with the window. After looking at it for awhile the ceiling texture seems a bit funny though. Not sure if it's the lighting, but it looks the same as the texture on the right wall but with grooves at a different angle. I would expect to see something without the grooves up there.
            Scrolling down I had the unusual circumstance of being able to see that bent grid structure against the sky before seeing it's connection to the ground plane. I have to say that I think I liked it better before I saw it against the ground plane. I would either rethink how it connects to the ground (sort of abrubt and at a weird spot on the grid) or even just cut the image off above the ground plane altogether. The second option might go well with some of your other more abstract images.
              dolphus
              Excellent but for my money the first one is spectacular very well done
                remus
                CHeeers for thr crits dolphus.
                Regarding the roof texture in the prison, yes it is wonky, but im doing a follow up image which will correct this and hopefully imprpve on it a bit. If not i might just go back and sort out the roof texture.
                With the big grid, i think its quite important to have it hitting a ground plane at some point, otherwise its just a big floating blob with no real purpose. The ground plane gives you an idea of what it is. I have to agree its intersecting at a bit of a strange place though, i didnt really think about it at the time. Unfortunately itd be very hard to go back and correct it so i'll probabky have to leave it as it is in it's mediocre state.
                • Y Offline
                  yannleo
                  all these images are amazing! I'm intersted in the holes with a specific bevel on the red sphere. I'm wondering how you could made it?
                    remus
                    It was originally a model of taff gochs (this one i ithnk: http://sketchup.google.com/3dwarehouse/details?mid=93b32636add99e0c50407bb2ce5f5c4f), then i just ran subd and smooth on the entire thing.
                    Not very creative really πŸ˜‰
                    • plot-parisP Offline
                      plot-paris
                      first image - shows a technical/mathematical understanding (even if not modelled by yourself πŸ˜‰ )
                      the clock - proves your ability to design real life objects (product design)
                      light bulb - shows that you know how to light objects. in addition to that it has a very artistic flair (this empty white room - the light the only object in it...)
                      the prison cell - is an impressive example how you can visualize the mood, the spirit of a room. it stays in strong contrast to typical, hygenic, sythetic cg-images. very impressive indeed!
                      the skeletal structure - shows your interest in engineering work (and impresses every architect deep down in his heart; a perfect weapon for a portfolio πŸ˜„ )
                      these are all good examples of your work and prove what you are capable of.
                      I am not so sure about the chairs however. even if the form is nice, they somehow do not impress (as much as the other images do); I am not sure, what they try to add to the documentation of your skills. perhaps because the render is not ideal (bit noisy).
                      could be a good idea to change the material (either add transparency to get some interesting caustic effects on the floor or work with bumb/displacement to get some sort of "furry" surface).
                        remus
                        i see what you mean about the chairs, to be honest im not really sure why i put them in there, i suppose it just seemed like a good idea at the time.
                        The clock isnt my design btw, its a bedroom clock ive got. Its a god point about including stuff ive designed though, so i suppose i could take out the clock and include some hand drawn stuff from my product design project last year.
                          plot-paris
                          oh, cool. do you mind posting some of it here? I am curious! πŸŽ‰
                            remus
                            Will do, although i need to get my folder back form college first, so its going to have to wait until mid september or so πŸ˜‰
                              pav_3j
                              i like it all. ten times better than any of the work in my portfolio.
                              do agree that the chairs could be better though, given the standard of the other things you have included (still very good though)
                              any chance of a tut on how you did the dome grid thingy (very precise as usual!)
                              lovely stuff
                              pav
                              Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                                remus
                                I posted it on here a while ago, although i'll be dammed if i can find it again.
                                Here it is again.
                                mesh structure tut.skp
                                  pav_3j
                                  awesome.
                                  you rock.
                                  let me buy you a beer.
                                  pav
                                    remus
                                    I might have to take you up on that one day πŸ˜„
                                      remus
                                      Ok, ive got a proper dilemma now, ive got to choose between the first image and the last image.
                                      Im tending towards the last one at the moment partly because i modelled it, but also because i think its more interesting model. I reckon it's also a bit more creative, as opposed to the first one which is more a showcase of that shiny red plastic material πŸ˜›
                                      Opinions please.
                                        plot-paris
                                        I agree with you. if you have to choose, take the last one. you named all the reasons already πŸ˜„
