    Drop question.......
    10 Posts 5 Posters 806 Views 5 Watching
    • W Offline
      wrecknball
      I have a bunch of plants that I want to drop onto a terrain I made. I saw a ruby here a while back that drop the instance at the intersection of the surface.
      Could someone please point me in the right direction? I tried doing a search, but there is a million searches with "drop" in it.
      Thanks.
      Shawn
        rhankc
        shawn,
        Go to : http://www.smustard.com/scripts/
        Look for 'Drop' it's free and I think TBD wrote it.
        HTH
        Hank
        • jujuJ Offline
          juju
          Could this Drop plugin be one you're referring to?
          +++ EDIT +++
          This is what happens when you open a whole bunch of window at once and then work your way through them - you get beaten to the punch line.
          • W Offline
            wrecknball
            I knew it was that one. For some reason mine was not working right. I re-downloaded it and replaced it. Works like a charm. Thanks.
            Shawn
            • jujuJ Offline
              juju
              Great to be of some help. You could also have a look at this one, Smartdrop.
                REGIS
                Perhaps you could try component spraytool.
                Rebards
                  jLon
                  hi,
                  i also do have a dop question. back while i was using sketchup v.5 i used to use a plug in to project my lines onto the terrain. the lines would get the shape of terrain and intersect it. now i did find some projection tools but they go perpendicular and its not the way i want them to work. i did download the "drop.rb" but when i put it into my plug in folder and open sketchup i cant see the drop option in my plug ins. can some1 help please?
                  thank you.
                  • jujuJ Offline
                    juju
                    I didn't really get into SU5, but I wonder if you're perhaps referring to the drape / stamp tool with the terrain modelling section of SU6.
                      jLon
                      yup actually i was talking about something like drape, but it doesnt work when i created a terrain w sandbox and then explode it.
                      i do wonder however why my drop.rb doesnt appear on plugins i m pretty sure i m doing something wrong but cant figure out why.
                      tyvm for checking out juju
                      • jujuJ Offline
                        juju
                        Drop doesn't appear in the plugins, it appears in the context menu (right click) of selected geometry.
