    [req] sketch fillet tool
    18 Posts 9 Posters 10.6k Views 9 Watching
      remus
      This is one of the few things i miss upon returning to SU after my brief flirtation with solidworks.
      Its basically a tool that lets you select 2 eddges, specify a radius and then draws in a suitable fillet.
      Any chance one of you lovely ruby people could knock this up? i'll buy you a pint...
      • plot-parisP Offline
        plot-paris
        could you post an explaining graphic, please? I am not sure, what you mean
          remus
          Start with this:
          http://farm4.static.flickr.com/3144/2695455334_5cea8bf345.jpg?v=0
          Select the 2 edges, type in a radius and get this:
          http://farm4.static.flickr.com/3093/2695455366_45d2091f95.jpg?v=0
            pav_3j
            yeah i can see how this could be useful, isn't it essentially the same as the bezier edge thingy?
            sorry for the lack of detail, i'm exceptionally tired.
            pav
            Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
              remus
              No, the bezier edge thing only works between 2 faces, i was thinking of this as working between 2 edges as in rounding one corner of a rectangle.
              Perhaps it could be built in to the bezier edge tool? (remeber that beer fredo πŸ‘ )
                pav_3j
                i stand corrected!
                personally i can't think of when i'd use it, but i'm sure i wouldn't be without it if i had it!
                pav
                  matt77
                  it already exists, try one of the rubies attached.
                  I cant remeber where i got these, so i cant take any credit for the actual scripts..
                  has worked a treat for me for awhile...
                  all the best
                  matt
                  FilletTool.rb
                    remus
                    Could you explain how it works please? i cant get it to work, keeps saying ive chosen a fillet radius greater than the width of the object, although it isnt.
                      FilletTool.rb is designed to make a rectangle with rounded corners. Like you Remus, I couldn't get away from the error message, though. I don't know how a 1 inch radius can be larger than a 24"x24" square.
                      Still, I don't think that's what you asked for is it, Remus? I don't see a second file, Matt.
                        remus
                        Your right dave, not quite what i was looking for.
                          matt77
                          give this ago...
                          might have to rename the files .rbs
                          as thats what they were originally....
                          .. i usually just select the 2 lines i want filleted , the put in the radius i want and thats it.
                          hopefully these should help, one is for the 3d stuff. which im sure i rember working.. I apologies if this isn't very specific, i havn't used them properly for awhile, and remeber it being fairly straight forward.
                          try Didiers site if not as most of my scripts are from there.
                          http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
                          hope these help
                          all the best
                          matt
                          fillet3D.rb
                          fillet.rb
                            remus
                            Couple of quick notes on those scripts: Both are .rbs files, so need to be renamed. fillet just plain doesnt work, ive got a feeling it hasnt been updated since v4, so that could be it. Fillet3d isnt what i was looking for, it just creates filleted geometry form input parameters (fileted cube etc.)
                            • fredo6F Offline
                              Remus,
                              If I understand correctly, you just need a round corner script, specifying a radius at the vertex between two edges.
                              As two edges are necessarily in a plane, there are exact geometrical solutions with circular arcs, as well as with Bezier curves (degree 2). For each one, you would need to set a number of segments indeed to play with the precision.
                              It is certainly feasible in Ruby. But I thought someone already did it. I remember there was another thread about the same subject (initiated by Ken), see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=8887&p=53692&hilit=round+corner#p53692.
                              But apparently this script fillet.rb does not work!
                              • W Offline
                                watkins
                                Dear Remus,
                                fillet.rb works fine for me.
                                Select your two edges and then go to Tools>Fillet
                                If you look at the lower left hand corner you will see that it is prompting you to enter the fillet radius. Enter a value in the VCB and hit return.
                                Regards,
                                Bob
                                  remus
                                  I missed the little prompt in the corner 😳
                                  Cheers for your help guys, got there in the end despite my incompetence πŸ‘
                                    Och, you're not incompetent. You're just working too fast. Probably comes from racing that tandem bike across the channel. πŸ˜„
                                      dtrarch
                                      2d fillet
                                      Just use the k_tools_50.rb ruby
                                      Geometry/make L option
                                      (you can asign a keystroke to this option and I use K)
                                      Just select the first line.
                                      Input the radius value and hit enter.
                                      Click on the second line and the radius is created.
                                      If the radius is zero this will trim/clear the two lines to a corner.
                                      Very handy when using SU in a 2d mode.
                                      Ruby can be found at
                                      http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_geo_page.htm
                                      dtr
                                        TonyF
                                        K-tools does the same job
                                        Use the Round Edge function.
                                        I have it assigned to a shortcut key.
                                        Works great!
