    Suspending the 'undo' stack
    8 Posts 5 Posters 1.3k Views 5 Watching
    • W Offline
      Whaat
      I am wondering if it is possible to disable the 'undo' feature of SketchUp. For example, in the context of a customized Ruby tool, I am performing a bunch of hiding and un-hiding of geometry while the user moves the mouse. Once the user leaves the tool, I don't want all of the hiding and un-hiding to be in the undo stack.
      I know about model.start_operation and model.commit_operation. These methods are not what I am looking for.
      • tbdT Offline
        tbd
        why not ? what operations are still inside the undo buffer ?
        http://plugins.ro
          RickW
          So, basically, you could be calling hundreds of changes to edges (hidden/not hidden), flooding the undo stack (limited to 100 operations) and basically eliminating the undo capability. I can see why that would be undesirable 😄
          IIUC, you want the changes to not be part of the undo stack at all, but the one option I know about is to trap all the changes in model.set_operation/commit_operation so they appear as a single undo item. The only thing relating to geometry manipulation that is "transparent" from ruby (that I know of) is the group.move! method.
          RickW
          www.smustard.com
          • W Offline
            Whaat
            Thanks guys,
            Maybe this snippet will explain what I am trying to do.
            def onMouseMove(flags, x, y, view)
            	if @hide
            		ph=view.pick_helper
            		ph.do_pick(x,y)
            		e=ph.best_picked
            		if e.class==Sketchup;;Group
            			if (test_condition)
            				e.hidden=true
            				@hidden.push(e)
            I don't want the hiding to be 'undoable'. When the user clicks the mousebutton, some geometry gets created. This is the operation that I DO want 'undoable' (which works fine). However, all of the hiding that is done in the 'onmousemove' method is also added to the undo stack. 😡
            • plot-parisP Offline
              plot-paris
              Whaat, I completely understand, why you need this.
              when I recently installed a v-ray trial version, exactly this happened to my SketchUp.
              when I for example copied a complex object within the stage and hit Ctrl + Z, it undid the copying prozess for every single element seperately, until it ran out of memory cash...
              I had to uninstall v-ray again to get rid of this unpleasant effect...
                RickW
                Unfortunately, that will have to be a v8 feature request. I can make that request (and I think it's a worthwhile one), but it won't be available for some time. For now, the best that can happen is collecting everything inside model.start_operation/commit_operation.
                Sorry...
                RickW
                www.smustard.com
                • fredo6F Offline
                  @whaat said:
                  Thanks guys,
                  > 	if @hide
                  > 		ph=view.pick_helper
                  > 		ph.do_pick(x,y)
                  > 		e=ph.best_picked
                  > 			if (test_condition)
                  > 				e.hidden=true
                  > 				@hidden.push(e)
                  > 			end
                  > 		end
                  > 	end
                  > end
                  I had the same issue with Joint Push Pull, as I do hide faces when dragging.
                  The workaround I found is to do a Sketchup.start_operationbefore all, and then do an Sketchup.abort_operationwhen the edition is finished (you have also to trap it in the OnCancel method). This way, you get nothing in the Undo stack and anyway, all individual operations are in the same batch of modifs.
                  • W Offline
                    Whaat
                    thanks Fred06! I'll try that!
