    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 185.5k Views 108 Watching
      digby dart
      Thank You! Yet another very impressive plug-in. 😄
        bianhai
        Thank You!!!
          Jon
          This looks like a great plugin! 😄
          Jon
          KT Team member
          • bigstickB Offline
            bigstick
            Any chance of either posting a version of the video we can view on OS X? I get a codec error in Quicktime using the WMV plugin. No Xvid for the Mac AFAIK.
              morisdov
              I am glad you like this, now lets see your creativity results.
              1. this plugin is written only in ruby, so it should be good for both mac & windows.
              2. when saving your sketchup model the "positions" are saved in it too, so if you email your model to a friend and he downloads this plugin, he should have the same animation functionality.
              3. this plugin uses the new SU version 6 "observer" class to hook into the "scenes" change, this "observer" is not called by SketchUp "Export -> Animation" so right now you cant standard export this to an AVI - just see it in sketchup.
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10926
                for the mean time hide the axes and use some screen capture utility to export videos.
              4. later i will add more than 4 positions, start experimenting very slowly.
              5. Youtube too does not like my wmv9 video - try
                http://www.metacafe.com/watch/1455250/morisdov_plugin_proper_animation_rb_for_sketchup/
                the resolution is terrrible but better than nothing
                i trust you come up with better viedos
              proper_animation_pics.zip
                marcosrodrigues
                Amazing! Thank you!
                | menos é mais
                  kwistenbiebel
                  @morisdov said:
                  3) this plugin uses the new SU version 6 "observer" class to hook into the "scenes" change, this "observer" is not called by SketchUp "Export -> Animation" so right now you cant standard export this to an AVI - just see it in sketchup.
                  Yes, it would be awesome if that could be supported.
                  Great job on that plugin 👍
                  • JClementsJ Offline
                    JClements
                    Morris:
                    Great work. I think everyone's hopes have been elevated.
                    We need to have a way for all .skps using your scripts to have a link embedded that will enable the anyone opening them to easily downloaded and install the proper script.
                    I suppose it could something as basic as floating text label with instructions if there was not a way to automate the process.
                    • FrederikF Offline
                      Frederik
                      Looks very promissing, but why does the object you animate "shrink" during the animation..?? 😕
                      I.e. a wheel turning on a motorbike will look a bit strange since it constantly change size during the animation... 😕
                      Cheers
                      Kim Frederik
                      • Mike LuceyM Offline
                        Mike Lucey
                        Morisdov, Wow, this looks amazing and I think the word 'PROPER'
                        well descibes what you have achieved. This is indeed very generous
                        of you 👍
                        Mike
                        • erikBE Offline
                          erikB
                          Yes, Morisdov great plugin but I also wonder why when rotating (p.e. doors) it isn't rotating but a sort of (as Kim stated)'shrinking, turning and expancing' movement.
                          greetings,
                          ErikB
                            morisdov
                            please download latest version 1.01 - should fix "shrink" on rotation.
                            • urgenU Offline
                              urgen
                              ....thanks! 👍 👍 👍
                              --pupil forever...------
                                I saw a post in the SketchUp forum about making a paper airplane animation. I was curious and thought I'd play with it. In the attached model, I've got two components. The triangular one is supposed to fold up. As it does, though, it moves away from the other component. When I rotated it, I rotated along the edge common to both. Is there a way to make the component "hinge" on the edge?
                                Folding Paper.skp
                                FWIW, it does seem to work properly for a hinging door.
                                hinged door.skp
                                • MALAISEM Offline
                                  MALAISE
                                  😍 very useful plugin, when you have to describe running machines without stopping them for safety reasons....
                                  👍 👍 👍 MALAISE
                                  • MALAISEM Offline
                                    MALAISE
                                    Hallo Morisdov
                                    Just my last drawing using your work...
                                    It's so easy to show complex movements ( here the Sample Handler on a Xray Spectrometer )
                                    👍 👍 😉 MALAISE
                                    Sample Handler simulation for Xray Ingeneering
                                    • F Offline
                                      Fletch
                                      Morisdov,
                                      thank you for sharing! (applause)
                                      this looks really great - can't wait to try it. 😄
                                      I noticed in your video that it appears the working of the rotate tool is SketchUp is still a bit frustrating for you... perhaps I'm wrong... if so, sorry - I mean no offense! It is a very difficult thing to master for many people I teach!
                                      The tip I give in training people in SU at our office is: when you go to place the center of the rotation tool protractor, click and drag (don't just click and release the mouse button right away) and PULL the center rotation axis of the tool (like the axis of a motor bike wheel) into an SU colored axis direction. then you will see it highlight as it locks the rotation tool onto that axis. Then let go of your mouse button when the rotate tool is locked into the axis you wanted. Then click first to set a 'base' 'zero' point... then START rotating in one or the other direction, THEN click your second point, or just type the angle you want after you have started it rotating.
                                      Fletch
                                      Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                                      • MALAISEM Offline
                                        MALAISE
                                        Hello Morisdov, 😄
                                        I'm really fond of your plugin.
                                        Some feedbacks : When using SketchyPhysics on the same time, Priority is given to SKPhysics, I've to activate continously the scene button to move slowly proper-animated groups. ( may be my 4 years old PC is little bit slow...)
                                        I've discovered that selecting all the scenes and apply them the same camera set-up, improves the reading. (Sorry for such a frenglish syntax 😳 )
                                        Do you know if it's possible to read "proper_animated skp files" on viewer as far as the plugin is needed to perform movements ?
                                        If someone knows how to insert plugin in SketchUp viewer, he is welcome...
                                        (I mean animations plugin and why not SketchyPhysics...)
                                        😉 MALAISE
                                          Does it possible to synchronize the Movement of the "proper animation" with the movement of the scenes?
                                          Sart --> end of Scene
                                          Start --> end of "Proper Animation"
                                          Of course I can reduce the speedy of the "Scene" by Animation / Settinds but that will be too speedy 😄
                                          In another word does it possible to setting "Proper Animation" speed? 😄
                                          In any case your plug is crazy fun ! 😎
                                          (load the Files then Plugins/ "Start animation observer" and run animation)
                                          (plugin proper_animation of course installed)
                                          exo.skp
                                          exo2.skp
                                            basic.woodworks
                                            If I understand your question correctly, go to Model Info. In the Animation tab, you can set the transition time within the scene for section planes to show and/or hide, as well you can set the transition time between one scene to the next. This will allow a pause of whatever seconds you want for someone to examine the scene or set it to 0 and allow a more fluid flow between scenes. You may still get a minor "jerk" appearance between scenes if the movement changes direction.
                                            BW
                                            "The greatest mistake a person can make is to be afraid of making one." (Elbert Hubbard)
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
