    Desk lamp
    15 Posts 6 Posters 2.7k Views 6 Watching
    • W Offline
      watkins
      Thanks Urgen!
      Thanks James!
      Praise from the both of you is praise indeed.
      Dear David,
      Yes, I did think about reducing the polycount, but my original intention was to while away a few hours modelling something close to hand (using a plastic ruler I eyeballed dimensions to get the proportions right). In that respect, low poly modelling was not my aim. I was also curious to see how well I could model the plastic components, which were far from simple shapes. The intersections went well and I was able to cleanup all redundant geometry, so I was pleased enough with the result to post here even though lamps are two a penny (or should that be two a dime). I thought about redrawing the spring component, but I had already spent too much time modelling so....
      When modelling something (like a household object), does the question, "Why!", ever enter your head, and do you just ignore it and carry on? Should I seek help?
      Kind regards,
      Bob
        Ross Macintosh
        Thanks Bob! I saved the one w/o springs and know it will come in very handy.
        Regards, Ross
          "When modelling something (like a household object), does the question, "Why!", ever enter your head, and do you just ignore it and carry on? Should I seek help?"
          πŸ˜†
          Yes, it does and yes, I do. I doubt there's much help that anyone could give.
          Keep doing it, Bob.
          Best,
          Dave
            dylan
            Thanks Bob for this great looking lamp. πŸ‘
            http://dmdarchitecture.co.uk/
              Hi All,
              If you don't need a very realistically looking spring for your lamp (i.e. to save geometry and for farther shots), you can use a semi transparent png texture positioned slightly rotated on the surface.
              Note that it runs around more than once so it is really not accurate for a spring but who cares from a distance? (I made it 1 cm wide and 10 cms long but you can adjust it to your needs).
              And the skippy:
              Spiral.skp
              • W Offline
                watkins
                Dear Dylan,
                Thank you for your kind comments. The lamp was really my way of improving my modelling skills. I am slowly working out how best to align parts, but I still found the springs tricky to position.
                Dear Gaieus,
                Many thanks for the semi-transparent texture. Would this be an application for the UV tool, say mapping concentric rings onto the walls of a cylinder? If so, then we might also have a new way of representing threaded parts.
                Regards,
                Bob
                  Gai,
                  That works very nicely for for a spring. Thanks for posting it.
                  Bob, I've used the Sketchy_Lines_Wavy materials to represent threads and it seems to be at least understandable. No UV mapping required for that. You just have to scale the texture down.
                    @watkins said:
                    ...Would this be an application for the UV tool, say mapping concentric rings onto the walls of a cylinder? If so, then we might also have a new way of representing threaded parts.
                    Regards,
                    Bob
                    I did not use the UV tools in this case (although it could be involved) because when I tried, it set it back to horizontal (maybe it could be used however but I just wanted to present a quick idea) if you mean that (if not, I1m not sure what you ment above - please, remember that English is not my mother tongue 😳 )
                      @gaieus said:
                      • please, remember that English is not my mother tongue 😳 )
                      Csaba, you'd never know it from your writing. Your English is a lot better than many Americans'. πŸ˜‰
                        Surely you haven't heard me speak yet! πŸ˜„
                          That's true. Do you Skype?
                            πŸ˜„
                            Search for gaieus (what else πŸ˜‰ )
