    Silvershadow's eye candy 1: The river runs thru it
    125 Posts 62 Posters 70.5k Views 62 Watching
    • urgenU Offline
      urgen
      ...Fine work, fine mood... ☀ 😄 let,s continue to create the similar further ... Many thanks! 👍
      --pupil forever...------
        GreyHead
        After I rendered the cobbles I remembered TIGs Matrix Proximity script. It allows you to create an array of components with some variation in size, placement and rotation. It adds an extra level of 'difference' if you need it.
        Bob
        PS For some reason about half of the cobbles turned over on dropping so I had to make both sides rounded.
          tomislavm
          This is one of the best I have ewer seen of sketchup,original and fascinating!
            dylan
            Thanks for the info on TIGs script Bob, that is a new one to me 👍
            http://dmdarchitecture.co.uk/
            • soloS Offline
              I cannot seem to locate it but I once remember talk about a 'Greeble' script, my thinking was that this too could be a solution.
              However Silver you certainly used SP in a very creative way.
                lapx
                I think it's part of the projection.rb ruby script. 😎
                  silver_shadow
                  GreyHead"]After I rendered the cobbles I remembered TIGs Matrix Proximity script. It allows you to create an array of components with some variation in size, placement and rotation.
                  thanx a lot, will have a look at this 😄 looks really cool
                    twharvey
                    @silver_shadow said:
                    :idea: ....comments are welcome... 💭
                    Hi Silver,
                    I followed your directions above and, after some fooling around, was able to duplicate your cobbles paved on a contoured surface. I did notice a couple of things to keep in mind for future projects: 1. The amplitude of the curved surface can't be very big (difference between high and low points) or the cobbles fall off. 2. The distance between the substrate and the cobbles must be minimized or the cobbles bounce when they hit and end up all over the place.
                    Thanks for the tut,
                    Tom
                    Tom
                      silver_shadow
                      yea i know. try this too
                      copy your site to a new drawing. rotate it to be not so steep.
                      Maybe you can try boxing it in also so nothing gets spilled. Try to divide the areas to controll groups and if it works, just remove the dividers afterwards. (just a thought 💭 )
                        Jim
                        It's not well documemented, but protrude can offset, protrude, and taper faces. Leave the second column blank unless you want a random number btween the range.
                        This model was produced using these inputs:
                        protrude.skp
                          silver_shadow
                          %(#BF0000)[STAGE 2 ➡ LIGHTING
                          Hi guys. Im moving now into stage 2 of my model.
                          but before i start i want to know, because we are having this discussion.
                          What is better for setting up light. Using sketchup's sun angles,or using multiple lights
                          omnis and rectangulars. I am not sure what the professional line prefer to use,
                          skylights stand alone, omni and rectangular lights. Im just asking in general, not specific sketchup only but in the modelling industry, what will be the best results you will get ❓]
                          • tinanneT Offline
                            tinanne
                            Wow, this is amazing! Thank you silvershadow for the generosity of your time in putting these together. I can't wait to try some of these out. You are very talented!
                            Executive Director : American Society of Architectural Illustrators
                            AIP 30 Competition opens soon. ASAI.org
                            Architectural Rendering
                              silver_shadow
                              yea im also a big fan of only using sky alone.. but i kind of like the omni and rec light also. The thing is.. but thats just me.. ive seen most professional people uses sometimes just this, omnis and rec lights. But then again, using sky, makes the model looks more realistic and not like its sitting on a set.
                                kwistenbiebel
                                The professional ones using the dinosaur packages (Max, Maya, etc...) would prefer a combo with additional directional/fill lights, as that would give full control over light setup.
                                Sometimes they need exactly 'that' ray of sun light hitting that exact spot of the model.
                                Personally I love to use Sky only and to see how far that brings me,because it would be closest to seeing reality. But that's from an architects standpoint.
                                Ask a graphical (3D) designer, and he will want to fine tune additional light sources to obtain exactly the effect he wants.
                                  kwistenbiebel
                                  True. It's 'the eye of the Beholder'.
                                  You can pick the images that were created by an architect from the ones created by a graphical artist.Different approach.
                                  • EddyNLE Offline
                                    EddyNL
                                    Hey silver_shadow, you've got some amazing SU models.
                                    Keep up the good work! 👍
                                    viewtopic.php?f=271&t=11903 Modelling my city for Google Earth!
                                    • StinkieS Offline
                                      Stinkie
                                      Might make a fine "community project". People run this one through the renderer of their choice, we bundle the renders, and send them to Google HQ. Message: we need high poly support. Of course, they could go: no, you don't, you're doing great without it. 💚
                                        silver_shadow
                                        thanx, i have build a lot of nice stuff but never finished it, kinda lost interest or don't have the time to finish it...its actually amazing i finished building this model lol
                                          kwistenbiebel
                                          lovely 👍
                                            silver_shadow
                                            [color=#BF0000]here you go guys. Hope you like it
                                            The only photoshop work that went into it was a colour correction and a bit of burning and lighting..
                                            http://i185.photobucket.com/albums/x165/hondsekont/alldone.jpg
                                            • 3 / 7
