    [Obsolete] Tools On Surface - v1.2
    62 Posts 38 Posters 31.7k Views 38 Watching
    • fredo6F Offline
      John,
      Could you give me more on the error (for instance on LineOnsurface), so that I can try to find out what's wrong with your set up.
      What bothers me however is that LineOnSurface has only 568 lines and you seem to get an error somewhere at line 899 !!!
      • ___olo_ Offline
        ___olo
        Thanks Fedro. it's very cool.
        Xin chào nhau giữa con đường
        Mùa xuân phía trước, miên trường phía sau
        • JClementsJ Offline
          JClements
          Fredo:
          I apologize for not responding sooner to your request. I just got back from the SU bootcamp.
          I showed what was happening to Todd B. He indicated that it is probably a bug and that I need to show you a larger display of the Ruby Console when it is running and that it might give you a better indication of what is going on. So stay tuned.
          If all else fails, I could try removing other scripts one by one and then test ... but I've got a lot installed so it would take a while to do that.
          The only thing on my pc that has changed on my PC (I am running XP on my PC) within the last couple of weeks that I know of is that my IT people pushed an upgrade for IE6 to IE7. I can't see how that would cause this problem, however .. particulary since your first version on the line worked when reinstalled.
            JClements
            Polygon on Surgace Tool:
              JClements
              Fredo: Here is some console outputs:
              Ruby Console, Line Tool:
              Ruby Console, Circle Tool:
              • fredo6F Offline
                It looks like you still have in your plugin folder an old file which has not been updated at the new version level 1.2 (apparently it loads an outdated definition of a structure called OFS_Node). This can possibly be OffsetOnSurface.rb (from version 1.0) or LibOnSurface.rb (from version 1.1). I don't think this is related to other scripts.
                So, just re-install version 1.2, making sure that you replace and overwrite all files "xxxxonsurface" (including theose you may have renamed).
                • soloS Offline
                  Totally agree with JClements. (on the last part)
                    JClements
                    Fredo:
                    Your recommendation posted immediately above this one worked! Thanks for your patience.
                    When I unzipped your download a few weeks ago, I told it to overwrite existing files, which it did; however, just prior to that I had renamed the initial LibTraductor.rb (but forgot to changen its extension).
                    Moral of the story, don't mess with things when you are tired or under pressure 😄
                    Regards, John
                    P.S. There was one hell of a lot of discussion and positive response to your scripts at Base Camp 2008. Even more surprising though was number of "professional" users who were totally unaware of the forum and the work that scripters here have been producing. I hope Google WILL DO MORE to enhance (promote) the "VISIBILITY" of this forum on their sites.
                      johnsenior1973
                      http://sketchupdate.blogspot.com/
                      "Vote now for your favorite lip warmer"
                      You've got to admit, that's much more interesting for most people than finding out news of a thriving SU community or the great work that's been done with Ruby's. Carry on Google staff, thrill us with tales about odd socks, navel lint, money lost in the sofa... 😒
                        lapx
                        I'll have to tell you guy's as much as you tell people about ruby's or even show them, they still have no idea how important it is to use them; about the value you get when in increasing productivity and enabling better techniques in model building. As with many here though, we look at the forum constantly to check for the latest and the greatest with frequent suprises. If you are going to use sketchup's power it's a must to read and understand how rubies imapct your process.
                        • E Offline
                          Emily
                          it's amaizing. i am sure it will be as powerful as 3D MAX to model anything.
                          • plot-parisP Offline
                            plot-paris
                            that is true. I spend several hours a day reading the scf forum. otherwise it is impossible to keep up with all the new information (of course it is because of the fun too!)
                            • chippwaltersC Offline
                              chippwalters
                              Wow. Sweet. Thanks so very much! You are very talented ☀
                              Currently working with Cross-Reality technologies
                              • I Offline
                                Iglesias
                                Thank you Fredo, outstanding
                                  ArkiX
                                  How can i say more about your "great job" ?!? 😍 ...maybe (if you help me how) i can help to translate it in italian to diffuse and use more.
                                  I mean... i tried immediately to translate it but, obviously, 😳 I am not a magician about Ruby script and I could not do this: I added and copied everything you have already done for the translation into French by putting | IT | and translating but ... nothing! does not work!
                                  You can, please help me?
                                  Thanks again for everything
                                  • fredo6F Offline
                                    ArkiX,
                                    Thanks in advance for the offer. I think it's wise to wait a little bit (at least next version 1.3) to have something more stable. I will then publish a clean text file for contributors to translate in their favorite language, and then integrate it myselffor release.
                                    By the way, the translated language should appear automatically based on your local Windows. If it is in Italian, then the script will use the strings with |IT|. Is it the case with your PC?
                                      ArkiX
                                      Thanks for your quick response,
                                      I wait for newer version with impatience and will be a great pleasure to participate in this and other your great scripts (even if only for translation); ☀
                                      Unfortunately, as shown in the "LibTraductor.def" I used | IT | but does not work (not charge more parts of the script translated), I also translated BezierSpline (bzstring.txt and quickreference) but then I do not know how to use them.
                                      Maybe because I'm on Mac 10.5.3 and SU6pro or perhaps because I have to reread "Tutorial Traductor" and above all understand. 😳 🤓
                                      Thanks again for now and waiting for your news and/or advices
                                      • Chris FullmerC Offline
                                        There is a link to it int he very first post of this thread. Here it is:
                                        404 Not Found
                                        (www.sketchucation.com)
                                        • I Offline
                                          Iglesias
                                          In this link you can download the script.
                                          http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_geo_page.htm
                                            jpalm32
                                            Best! 5 *****; Took awhile to get used to but greatfor cutting through odd shapes.
                                            Used to cut 3D corrugated roof panel and add shapes for connections. I don't know how long this what have taken w/o this.
                                            Thanks!!
                                            • 3 / 4
