    [Plugin] 3d Shapes Tool (was: Pyramid Tool)
    53 Posts 21 Posters 50.9k Views 21 Watching
      CPhillips
      @jclements said:
      Hi Macs:
      Request to add drawing an equal-sided cube (or maybe elongated one also?) from the center of the first mouse-click. If there was a way to alternate to starting from a corner that would be cool, but not essential.
      And, since SU's rectangle tool doesn't have an option to create a rectangle from its center, this cube tool could also be used to do this by simply not moving the mouse along a third-axis for the 3rd mouse-click (or by double-clicking on the 2nd mouse-click).
      Regards, John.
      I like the idea of a center version of shapes. How a shape (or even a line) is centered would be a great option at almost every step in the process. I was thinking that the CTRL key could toggle whether that state (width,height,depth) of the shape is centered or not. That is sort of how the sphere in the SketchyPhysics solids work.
        OFFTOPIC:
        Mirror.rb script hands and can also copy the objects if desired - like ACAD...
        • JClementsJ Offline
          JClements
          Chris, I agree. This would be consistent with other SU tools such as the Scale tool.
          OFFTOPIC:
          1. A big gripe of mine is being able to scale from the center of a selection along ONLY TWO AXIS directions with one mouse-drag sequence or one entry in the VCB. Primarily at equal distances from the center. I am wondering if some of the coding included in these new hybrid tools could utilized to create such a script?
          2. Also, when Dragging a side selection handle, you mirror or "flip" an object. However, manytimes I'd like to COPY the flipped object. In some of my 2d apps when dragging an object with the left-mouse depressed, I can drop a copy by clicking and releasing the right-mouse buttom while the left is still depressed. I think this would be a good solution for a similar SU flip-and-copy script.
            pav_3j
            ah very neat lil ruby there. thank you for the hard work.
            pav
            Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
              Macs
              I've finished the work on icosahedron too,
              now I will try to implement feature you all request and clean the code a little.
              see you next week.
                agrazdi
                Is it possible to assign a shortcut key to " create a Box " for instance.?
                  Macs
                  I've updated the script see first post for details,
                  here the new toolbar with new shapes.
                  enjoy πŸ˜‰
                  • urgenU Offline
                    urgen
                    ... Thanks Macs, it,s very useful work. πŸ‘ I like it... πŸ˜„
                    --pupil forever...------
                      Macs
                        JClements
                        No cube/square from center? I tried the pyramid tool to do this with the last click on the same Z plane as the other clicks but, of course, I then get a square or rectangle with diagonals from corner-to-corner.
                          Macs
                          I think you can do this with the standard polygon tool and setting 4 sides in VCB
                            sherwood11
                            This tool (version 1.1) seems very useful .. However, It won't work for me.
                            It will not complete after the last input
                            and the blue-pencil pointer stays visible.
                            It won't complete after :
                            Cone or Pyramid, 3rd click
                            Sphere, 2nd click
                            Rotated Pyramid, 4th click
                            Dodecahedron, 2nd click
                            Icosahedron, 2nd click
                            Any thoughts ?
                            Is there some kind of setting in SU ?
                            IE., Cone or Pyramid - Ruby console :
                            Error: #<NoMethodError: undefined method GetString' for nil:NilClass> C:/Program Files/Google/Google SketchUp 8/Plugins/3dshapestool.rb:616:in create_geometry'
                            C:/Program Files/Google/Google SketchUp 8/Plugins/3dshapestool.rb:555:in increment_state' C:/Program Files/Google/Google SketchUp 8/Plugins/3dshapestool.rb:213:in onLButtonDown'
                            Many Thanks,
                            I found a solution !
                            the problem is with this line in the script :
                            model.start_operation $exStrings.GetString("shapename")
                            I could not find the .GetString method anywhere ( after more hours of research than I care to mention).
                            apperantly, this error message occurs often without meaningfull documentation to remedy. I think
                            .GetString is some sort-of depricated method in Ruby or OpenGL or something like that ... 😠
                            I created a class variable for each shapename
                            placed between 'class PyramidTool' (line 29) and the first 'def Initialize' (line 36 +- ) :
                            @@threedcone = "Cone"
                            @@threedpyramid = "Pyramid"
                            @@threedsphere = "Sphere"
                            @@threedpolyhedron = "Polyhedron"
                            @@threeddodecahedron = "Dodecahedron"
                            @@threedicosahedron = "Icosahedron"
                            Then I simply replaced every occurance (7) of:
                            with,
                            model.start_operation @@_shapename_ . . . . eg. @@threedcone
                            Done . . . I hope this helps anyone having this problem with the .GetString method
                            I have several scripts with this that do work ... but, I plan on modifing them also.
                            Cheers
                              johnwmcc
                              I've just tried this in Sketchup Make 2013, as this no longer has the 3D shapes built in to the free version.
                              It crashes Sketchup completely every time ("The Sketchup Application has stopped working"), on the third click to set height(for cone or pyramid) even after system restart, and using the plugin in a completely new drawing.
                              There's no error message in the Ruby console, just the crash. Entirely repeatable, unfortunately.
                              Is there an update available that would fix this?
                              I can't find any other equivalent plugin: if anyone knows of another, I'd be grateful for a pointer to it.
                              John McClenahan
                              PS. Have just found the Shapes plugin by the Sketchup team, in the Extension Warehouse. That will do very well. In earlier versions of SU I thought it got installed by default, but it wasn't in SU Make 2013.
                                TANER TAN
                                Is there working version for Sketchup 2013?
                                  See the preceding post - and get the similar SketchUp guys' Shapes tool from the EW...
                                  There is no obvious reason why this very old 3d Shapes Tool should NOT work in SketchUp v2013...
                                  BUT I confirm that it does crash it !
                                  BUT it is ~6 years old, so what would you expect ?
                                  There's probably some simple re-coding fix, I'm too busy to dig into it know, why not pester the author Macs ?
                                  The EW toolset is very similar - and more comprehensive ???
                                  I have added a warning note to the download page and equivalent PluginStore item...
                                    man
                                    loving this tool mate. thanks
                                      Shortstuff81000
                                      I love this tool! πŸ˜„ I wish it was compatible with the latest version of SU; I like to use the mouse to draw my shapes rather than use dialog boxes. 😒
                                      • TAYEBIT Offline
                                        TAYEBI
                                        Can’t someone take a look at its code and make it work with newer versions of SU??
                                        This tool is far more better and user friendlier than any other similar tools..
                                        PLEASE make it work ... God blesses you, dear developer ..
                                        πŸ˜‰
                                          Pherim
                                          I would also love to see this made compatible with newer versions.
                                          • 2 / 3
