    Render #22 (animation test bottom page 8)
    120 Posts 30 Posters 20.5k Views 30 Watching
    • T
      tomislavm
      Great, what kind of bildong is that?
      • P
        pav_3j
        very nice design, and render.
        it's very alsopp meets dr. who.
        tasty
        pav
        Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
        • boofredlayB
          boofredlay
          What is a bildong? I think I might be afraid to know the answer. 😉
          Great render Chris! I would have called it "The Arc's Landing" or some such thing.
          • GaieusG
            Not the renders that strikes me (we are getting used to Kwists rendering abilities) and maybe not even the modeling part ("we are getting used to it...") but the idea, the concept!
            Really great! Please, more of this kind of fantasy creations! I just LOVE them! 👍
            • chavinskeeC
              chavinskee
              fantastic work as always!!! what renderer did u use?
              http://chavinskee.blogspot.com/
              • marked001M
                marked001
                #22? i think you mean 220...haha..... looks awesome. is this Fry?
                http://www.revision21vis.com
                instagram: revi21on
                  sepo
                  love the form 😎 ...could you tell us was it difficult to extrude window frames on curved surfaces. I guess surface tools and new JV push -pull was used.
                  • FrederikF
                    Frederik
                    I assume that you're right, Sepo...
                    But the texture job is really good as well..!! 👍
                    Care to share how you did this, Chris..?? 😉
                    Cheers
                    Kim Frederik
                    • K
                      kwistenbiebel
                      Thank you guys 😄
                      Indeed, the "surface tools" and "joint-push-pull" tools were used here to make those windows.
                      And off course 'subsmooth' (though I think it should have had one iteration more).
                      @Frederick,
                      I just used the 'projected' method. It stretches the texture but it was not so disturbing this time. It depends from which angle you project the texture I guess.
                      • K
                        kwistenbiebel
                        A quickie (noisy) using only background light (white):
                        http://i140.photobucket.com/albums/r3/kwistenbiebel1/project22bis.jpg
                        • I
                          igor
                          how did you get such beautiful wood paneling? i mean in terms of projecting it onto the building (a really good building btw). did you project it at an angle (set up a face at a 45 degree angle instead of flat front or back)? like this:
                          ../ __________
                          ./ |.building.|
                          / .|________|
                          the three slashes on the left = face from witch the texture is projected
                          box = you guessed it, is the building.
                          little tiny dots = nothing, just ignore them.
                          am i right?
                          The genius switch has no "off" position
                          Intelegence is natrual, it takes real effort to be ignorant
                          • N
                            nomeradona
                            hey kwist, this is another fabulous render and concept. is this Biebel's ark or tower of Biebel? 😄
                            • K
                              kwistenbiebel
                              Thanks Nomer ...An Ark, didn't think about that 😄
                              I re-rendered the last view using Physical sky. (Indigo render)
                              The subtle glare is added 'internally' in the Violet tonemapper.
                              The glass should have had a little less roughness...
                              To view full size: (Firefox:right click- view image) (IExplorer:right click - image save as)
                              http://i140.photobucket.com/albums/r3/kwistenbiebel1/project22-view3.jpg
                              • K
                                kwistenbiebel
                                Thank you Fred and Igor.
                                @Igor: You are correct. I projected the image almost perpendicular to the 'corner' of the building (as in your scheme).
                                I must admit the projecting is view dependant. Choose another viewpoint and the projecting needs to be redone.
                                • FrederikF
                                  Frederik
                                  Thanks for the answer regarding the texturing, Chris..!! 😉
                                  It looks as 3D trees... Xfrog..?? 😎
                                  And the people in the scene... 😲
                                  These are for sure some really excellent reders..!! 👍
                                  Cheers
                                  Kim Frederik
                                  • K
                                    kwistenbiebel
                                    Gracias senor Frederico 😄
                                    The trees are Xfrog, the people Axyz as they look ok seen from a distance.
                                    When in close-up, the Axyz guys look a bit like melted E.T.'s though 😆
                                    • F
                                      fbartels
                                      Chris, Nice work. I like where these seem to be heading. Zaha watch out indeed. Fred
                                      • K
                                        kwistenbiebel
                                        Some more:
                                        Ouch....distorted texture alert 😄
                                        http://i140.photobucket.com/albums/r3/kwistenbiebel1/render22view4.jpg
                                          Is it for the fun or for real or hypothetic project ❓
                                          Is it the new Noe's Arche? ☀
                                          • K
                                            kwistenbiebel
                                            Well this one is for sport ...
                                            I was thinking that modeling something realistic (I know it is not though ) was a good way to get to know the new organic rubies and to practice them.
                                            Besides, I consider it also a bit as portfolio filling ...Play becomes work becomes play 😉
                                            • 1 / 6
