    Render #22 (animation test bottom page 8)
    120 Posts 30 Posters 16.3k Views 30 Watching
    • marked001M Offline
      marked001
      #22? i think you mean 220...haha..... looks awesome. is this Fry?
      http://www.revision21vis.com
      instagram: revi21on
        sepo
        love the form 😎 ...could you tell us was it difficult to extrude window frames on curved surfaces. I guess surface tools and new JV push -pull was used.
        • FrederikF Offline
          Frederik
          I assume that you're right, Sepo...
          But the texture job is really good as well..!! 👍
          Care to share how you did this, Chris..?? 😉
          Cheers
          Kim Frederik
            kwistenbiebel
            Thank you guys 😄
            Indeed, the "surface tools" and "joint-push-pull" tools were used here to make those windows.
            And off course 'subsmooth' (though I think it should have had one iteration more).
            @Frederick,
            I just used the 'projected' method. It stretches the texture but it was not so disturbing this time. It depends from which angle you project the texture I guess.
              kwistenbiebel
              A quickie (noisy) using only background light (white):
              http://i140.photobucket.com/albums/r3/kwistenbiebel1/project22bis.jpg
              • I Offline
                igor
                how did you get such beautiful wood paneling? i mean in terms of projecting it onto the building (a really good building btw). did you project it at an angle (set up a face at a 45 degree angle instead of flat front or back)? like this:
                ../ __________
                ./ |.building.|
                / .|________|
                the three slashes on the left = face from witch the texture is projected
                box = you guessed it, is the building.
                little tiny dots = nothing, just ignore them.
                am i right?
                The genius switch has no "off" position
                Intelegence is natrual, it takes real effort to be ignorant
                • N Offline
                  nomeradona
                  hey kwist, this is another fabulous render and concept. is this Biebel's ark or tower of Biebel? 😄
                    kwistenbiebel
                    Thanks Nomer ...An Ark, didn't think about that 😄
                    I re-rendered the last view using Physical sky. (Indigo render)
                    The subtle glare is added 'internally' in the Violet tonemapper.
                    The glass should have had a little less roughness...
                    To view full size: (Firefox:right click- view image) (IExplorer:right click - image save as)
                    http://i140.photobucket.com/albums/r3/kwistenbiebel1/project22-view3.jpg
                      kwistenbiebel
                      Thank you Fred and Igor.
                      @Igor: You are correct. I projected the image almost perpendicular to the 'corner' of the building (as in your scheme).
                      I must admit the projecting is view dependant. Choose another viewpoint and the projecting needs to be redone.
                      • FrederikF Offline
                        Frederik
                        Thanks for the answer regarding the texturing, Chris..!! 😉
                        It looks as 3D trees... Xfrog..?? 😎
                        And the people in the scene... 😲
                        These are for sure some really excellent reders..!! 👍
                        Cheers
                        Kim Frederik
                          kwistenbiebel
                          Gracias senor Frederico 😄
                          The trees are Xfrog, the people Axyz as they look ok seen from a distance.
                          When in close-up, the Axyz guys look a bit like melted E.T.'s though 😆
                          • F Offline
                            fbartels
                            Chris, Nice work. I like where these seem to be heading. Zaha watch out indeed. Fred
                              kwistenbiebel
                              Some more:
                              Ouch....distorted texture alert 😄
                              http://i140.photobucket.com/albums/r3/kwistenbiebel1/render22view4.jpg
                                Is it for the fun or for real or hypothetic project ❓
                                Is it the new Noe's Arche? ☀
                                  kwistenbiebel
                                  Well this one is for sport ...
                                  I was thinking that modeling something realistic (I know it is not though ) was a good way to get to know the new organic rubies and to practice them.
                                  Besides, I consider it also a bit as portfolio filling ...Play becomes work becomes play 😉
                                  • tinanneT Offline
                                    tinanne
                                    Wonderful work Chris, as usual. I really enjoyed "exploring" from you different views!
                                    Executive Director : American Society of Architectural Illustrators
                                    AIP 30 Competition opens soon. ASAI.org
                                    Architectural Rendering
                                      mateo soletic
                                      Chris, Great work, thanks for sharing. 👍
                                      [Concept Illustrations](http://concept-illustrations.com/)
                                        remus
                                        That last one looks like a giant 70s spaceship just landed in someones back garen during a bbq (and no one noticed.)
                                          kwistenbiebel
                                          Thank you Tinanne and Mateo,
                                          Let me finish with the same view but different material use. Quite a different appeal:
                                          http://i140.photobucket.com/albums/r3/kwistenbiebel1/metal-facade.jpg
                                          • I Offline
                                            igor
                                            • 1 / 6
