    SDS & FFD Abstract Sculptures with Interesting Textures
    38 Posts 15 Posters 7.5k Views 15 Watching
      princedragoncok
      That texture did come out well indeed. I like the way it morphs into the next, quite cool
        kwistenbiebel
        Very interesting shapes.
        If you watch them closely, you can distinguish human figures or other things, just like you can in cloud configurations.
        Very good phsycho evaluation test. 😄
        • StinkieS Offline
          Stinkie
          Indeed! The last one strongly resembles a naked dwarf riding a unicycle, don't you think?
          Nice experiments, Fred.
          • F Offline
            fbartels
            More Rorschach tests for KB et al. If only these textures worked with shadows. 😢
            http://dws.editme.com/files/MayJune2008/trans text test 5.jpg
            http://dws.editme.com/files/MayJune2008/trans text test 4 .jpg
            http://dws.editme.com/files/MayJune2008/trans text test 3.jpg
            • FrederikF Offline
              Frederik
              These are indeed very interesting shapes and textures..!! 👍
              Cheers
              Kim Frederik
                kwistenbiebel
                Fred, a little question:
                How do you texture these shapes?
                My freeforms have screwed up uv's all the time.
                I have a headache trying to get a brick texture or other tiling texture on them.... 😠
                Damn sketchup!
                • F Offline
                  fbartels
                  biebel, (I'll just rotate through the various name permutations)
                  Nothing to the texturing I'm doing. I just import an image, explode it, size and orient it as needed, sample it with the paint tool (by holding down the Command key), then select the surface I want to project upon, and paint it with the texture. With transparent areas in the texture you need to do the same steps on the inside surface as well. I just show hidden geometry, delete a triangle, double click on the inner surface, paint, then paste in place the deleted triangle.
                  Fred
                    kwistenbiebel
                    Thanks Fred,
                    That is the same 'projeting' technique I use, but it is very limited.
                    I was hoping there were some advanced tricks I am not aware of.
                    • soloS Offline
                      Fred, these look awesome I especially like the mesh textured one's. One solution to the shadows would be to make the mesh a clip-map or alpha map and render it, this would give you the correct shadows.
                      • F Offline
                        fbartels
                        Chris... I agree about the limitations being a pain, I just try to work within/around them.
                        Pete... I really, really, really need to find the time to learn how to do rendering. 😞
                        Some new ones. I've got to stop this.
                        http://dws.editme.com/files/MayJune2008/ttt 4 v2.jpg
                        http://dws.editme.com/files/MayJune2008/ttt 4 v1.jpg
                        http://dws.editme.com/files/MayJune2008/ttt 4 v4.jpg
                        • I Offline
                          igor
                          no! dont stop! these are awsome. i especialy like those last ones, they remind me of glass with stripes of colored glass inlayed with it.
                          and if you cant find the time to learn how to render stuff, just use podium. its as intuitive and easy to learn as SU. plus its pretty dang fast.
                          i serriously need to get this pluggin.
                          The genius switch has no "off" position
                          Intelegence is natrual, it takes real effort to be ignorant
                            remus
                            Those last ones are very cool fred, i look forward to you learning to render, i tihnk we could have some interestign stuff being posted 😄
                              Can you use some texture like this or must it be tiling seamless?
                              (here Zbrush doodling)you can find some on my "Speedy galerie" free to you to use them 😉
                              • E Offline
                                ehaflett
                                Great stuff Fred, your posts never disappoint and always entertain.
                                  lapx
                                  Great images Fred don't stop posting please!
                                  • F Offline
                                    fbartels
                                    Thanks all, for the kind comments. One more experiment.
                                    http://dws.editme.com/files/MayJune2008/sds last one v5.jpg
                                    http://dws.editme.com/files/MayJune2008/sds last one v4.jpg
                                    http://dws.editme.com/files/MayJune2008/sds last one v3.jpg
                                    http://dws.editme.com/files/MayJune2008/sds last one v1.jpg
                                    • soloS Offline
                                      oooh! that looks like one of the deep ocean creatures from the BBC Planet earth series.
                                        kwistenbiebel
                                        Love'em !
                                        • F Offline
                                          fbartels
                                          Just a couple more. One, a final export from last night in which I removed the screen "shadow" shapes, and the other from a quick experiment using follow-me to create the proxy shape to feed into SdS. Quite a bit of potential there I think. (Chris.. btw, I enjoyed your original pre self-censored comment. 😉 😄 )
                                          http://dws.editme.com/files/Home/sds last one v7.jpg
                                          http://dws.editme.com/files/Home/sds 8 v2 sm.jpg
                                          • ___olo_ Offline
                                            ___olo
                                            I have a litte question, how do you paint the map on your model ???
                                            Xin chào nhau giữa con đường
                                            Mùa xuân phía trước, miên trường phía sau
