    SDS & FFD Abstract Sculptures with Interesting Textures
    38 Posts 15 Posters 6.3k Views 15 Watching
    • F Offline
      fbartels
      I used two previously created models to produce this abstract sculpture. One, for the SDS proxy, was a set of stacked twist rhombic dodecahedrons which I uploaded to the 3d-warehouse almost 2 years ago. The second, which I made earlier today, provided the texture via a screenshot of an exported image (see below). If nothing else, my building models often provide interesting textures for my abstract sculptures. I love it when I can repurpose old work.
      http://dws.editme.com/files/MayJune2008/sculpture from trd small.jpg
        That is some fractal if your abstract sculptures often provide interesting textures for your building models 😄
        An infinite circular loop! 😎
        • F Offline
          fbartels
          Pilou, It is important to stay away from those infinite circular loops. 😮 Fred
          Another experiment both with SDS and transparent textures.
          http://dws.editme.com/files/MayJune2008/sds 6 v4.jpg
          http://dws.editme.com/files/MayJune2008/sds 6 v2.jpg
            princedragoncok
            That texture did come out well indeed. I like the way it morphs into the next, quite cool
              kwistenbiebel
              Very interesting shapes.
              If you watch them closely, you can distinguish human figures or other things, just like you can in cloud configurations.
              Very good phsycho evaluation test. 😄
              • StinkieS Offline
                Stinkie
                Indeed! The last one strongly resembles a naked dwarf riding a unicycle, don't you think?
                Nice experiments, Fred.
                • F Offline
                  fbartels
                  More Rorschach tests for KB et al. If only these textures worked with shadows. 😢
                  http://dws.editme.com/files/MayJune2008/trans text test 5.jpg
                  http://dws.editme.com/files/MayJune2008/trans text test 4 .jpg
                  http://dws.editme.com/files/MayJune2008/trans text test 3.jpg
                  • FrederikF Offline
                    Frederik
                    These are indeed very interesting shapes and textures..!! 👍
                    Cheers
                    Kim Frederik
                      kwistenbiebel
                      Fred, a little question:
                      How do you texture these shapes?
                      My freeforms have screwed up uv's all the time.
                      I have a headache trying to get a brick texture or other tiling texture on them.... 😠
                      Damn sketchup!
                      • F Offline
                        fbartels
                        biebel, (I'll just rotate through the various name permutations)
                        Nothing to the texturing I'm doing. I just import an image, explode it, size and orient it as needed, sample it with the paint tool (by holding down the Command key), then select the surface I want to project upon, and paint it with the texture. With transparent areas in the texture you need to do the same steps on the inside surface as well. I just show hidden geometry, delete a triangle, double click on the inner surface, paint, then paste in place the deleted triangle.
                        Fred
                          kwistenbiebel
                          Thanks Fred,
                          That is the same 'projeting' technique I use, but it is very limited.
                          I was hoping there were some advanced tricks I am not aware of.
                          • soloS Offline
                            Fred, these look awesome I especially like the mesh textured one's. One solution to the shadows would be to make the mesh a clip-map or alpha map and render it, this would give you the correct shadows.
                            • F Offline
                              fbartels
                              Chris... I agree about the limitations being a pain, I just try to work within/around them.
                              Pete... I really, really, really need to find the time to learn how to do rendering. 😞
                              Some new ones. I've got to stop this.
                              http://dws.editme.com/files/MayJune2008/ttt 4 v2.jpg
                              http://dws.editme.com/files/MayJune2008/ttt 4 v1.jpg
                              http://dws.editme.com/files/MayJune2008/ttt 4 v4.jpg
                              • I Offline
                                igor
                                no! dont stop! these are awsome. i especialy like those last ones, they remind me of glass with stripes of colored glass inlayed with it.
                                and if you cant find the time to learn how to render stuff, just use podium. its as intuitive and easy to learn as SU. plus its pretty dang fast.
                                i serriously need to get this pluggin.
                                The genius switch has no "off" position
                                Intelegence is natrual, it takes real effort to be ignorant
                                  remus
                                  Those last ones are very cool fred, i look forward to you learning to render, i tihnk we could have some interestign stuff being posted 😄
                                    Can you use some texture like this or must it be tiling seamless?
                                    (here Zbrush doodling)you can find some on my "Speedy galerie" free to you to use them 😉
                                    • E Offline
                                      ehaflett
                                      Great stuff Fred, your posts never disappoint and always entertain.
                                        lapx
                                        Great images Fred don't stop posting please!
                                        • F Offline
                                          fbartels
                                          Thanks all, for the kind comments. One more experiment.
                                          http://dws.editme.com/files/MayJune2008/sds last one v5.jpg
                                          http://dws.editme.com/files/MayJune2008/sds last one v4.jpg
                                          http://dws.editme.com/files/MayJune2008/sds last one v3.jpg
                                          http://dws.editme.com/files/MayJune2008/sds last one v1.jpg
                                          • soloS Offline
                                            oooh! that looks like one of the deep ocean creatures from the BBC Planet earth series.
