    Prism problem
    38 Posts 14 Posters 4.2k Views 14 Watching
    • ely862meE Offline
      ely862me
      sorry if i post too much but i want to see how far can we go so i choose 1000 segments for circles and we are very close
      Elisei (sketchupper)
      Come and See EliseiDesign
      • ely862meE Offline
        ely862me
        the circles will meet but the problem is that the circles aren t perfect they haven t infinite points and they won t meet in the perfect point
        as u ll see is almost good after the rotation of the triangles at that point, but isn t fitted because the circle isn t infinite;so i fitt them by hand after rotation and "voila!"
        "The problem is that SU cannot snap to edges when rotating and this makes us need to find out workatrounds all the time."(Gaeius) this is the main problem
        i wasn t pleased so i scale it and finally i saw the differences but they are verry smallprism1.jpg
        i used circles with 200 segments u ll use with more segments will be much closer but never perfect
        • BepB Offline
          Bep
          Hello fruitjelly,
          Is this the solution your looking for.
          greetings
          Bep van Malde
          "History is written by the winners"
          • I Offline
            igor
            here is my way: (note that i didnt read all the posts, so someone might have already said this)
            make an equilateral triangle. since its equilateral, all the angles should be the same (60 degrees). copy-rotate it (rotate tool + ctrl) up 60 degrees. and then you...
            opps, i just checked to see if my method would work, i doesnt. <insert homer simpson esque "d'oh" here>. sorry for taking up space with a non-helpful post
            and i have now looked at the previous posts and realized you have some very good help. good luck!
            The genius switch has no "off" position
            Intelegence is natrual, it takes real effort to be ignorant
            • Didier BurD Offline
              Didier Bur
              This is called a tetrahedron:
              http://en.wikipedia.org/wiki/Tetrahedron
              DB
                Oh yes, and there is a "ready made" one in the shapes library - but how do we make one (without maths)?!
                  Jim
                  This animation from Wikipedia shows it's really very simple! (Inside a cube.)
                    remus
                    Good find jim.
                    Still quite a way out though 😉
                    http://farm4.static.flickr.com/3003/2522211423_ee5c428b5e_o.jpg
                    I also tried rotating a copy of the base triangle in to place by the dihedral angle (accurate to 6 decimal places) and that is still quite a way out as well. about 0.7% if i remeber correctly.
                      Gee Jim,
                      That's indeed very simple! 😲
                      • Wo3DanW Offline
                        Wo3Dan
                        Unfortunately I have not found a solution for this problem in general (i.e. rotate/snap by pure construction), see attachment below.
                        For special cases like the one presented here by fruitjelly (a tetrahedron) there always seem to be good workarounds. So next question: How would you solve the rotation in the attached model to get the one and only edge AB?
                        (We had this discussion before about creating the perfect buckyball but that's also a special case)
                        RotateSnapProblem.skp
                          Ah, Wodan,
                          I remember this challange. I even have a "no-solution" version of this among my models at the WareHouse: http://sketchup.google.com/3dwarehouse/details?mid=8075be6a6da45be3d2f8fef8fa52eceb
                          Actually the exact same problem as here...
                          • F Offline
                            fruitjelly
                            Jim's image so far best illustrates the easiest way to for that shape. Then again, if ultimately, we want a equilateral triangle with for example 1m on each side.... We have to use maths, such as pythagoras theorem, but the weird never ending figures simply will not produce an accurate shape.
                            So do you guys think its ok to say that, as far as complicated geometry are concerned (especially with arcs and curves), sketchup ain't that useful when dealing with accuracy.
                            Modeling this tetrahedron had been a real pain, but turns out the solution is a damn cube....
                            • jujuJ Offline
                              juju
                              It's a known fact that SU accuracy isn't the best around, but then again it isn't meant for creating geometry smaller than the feet of a dust mite.
                              • AnssiA Offline
                                Anssi
                                @fruitjelly said:
                                Then again, if ultimately, we want a equilateral triangle with for example 1m on each side.... We have to use maths...
                                No we don't - we use the Tape measure tool. Make a triangle of any size, measure the side, and type the length you want, and press Enter. SU asks if you eant to resize the model, click OK, and you are done. If you have other things in your model that you don't want resized, group the triangle, and do the trick inside the group.
                                Anssi
                                  remus
                                  Even the cube method isnt entirely accurate, see my previous post.
                                  • jeff hammondJ Offline
                                    really? i did the cube method 3 times and it always worked out perfectly.. every edge was the same length.. or maybe i'm not understanding something?
                                      remus
                                      Hmmm, perhaps i made a mistake when i did it, i'll give it a go when i get home.
                                      • V Offline
                                        Voder Vocoder
                                        As long as we're looking things up on Wikipedia, we can see that it gives the dihedral (included angle between two adjacent faces) of a tetrahedron as 70.528779°. That gives us the following very simple construction:
                                        http://saveimage.eu/showoriginal-35/tet.jpg
                                        ~Voder
                                          i think the challenge is to build the shape entirely using sketchup tools and locks.. the cube method makes this possible.. your solution uses math (albeit you went straight for the answer but 70.52....deg is a solution for an equation)..
                                          here's an easy method for drawing an equilateral triangle without entering any numbers... [edit] - using this same method should work for for the entire shape but i'm having weird snap to problems.. i'll mess around with it tomorrow.. goodnight..
                                          triangle.skp
                                            remus
                                            I must have been doing something weird when i tried that cube method originally, works like a charm now.
