    Too many toolbars
    10 Posts 5 Posters 1.3k Views 5 Watching
    • EdsonE Offline
      Edson
      every time i open SUp a lot of toolbars show up on the screen, most of them not needed and unwanted. what can i do to keep them hidden at startup? i have tried hiding them and saving a new template but it did not work.
      i hope someone has the answer for that.
      http://www.mahfuz.arq.br
        remus
        Cant you hide them through view->toolbars?
        If not id guess it's a bug in the mac version πŸ˜‰ Better wait for a mac perosn to give the definitive answer though.
        • EdsonE Offline
          Edson
          i certainly can do that but this is the point: i do not want to do it every time SUp starts! i want to find a way to leave them hidden always.
            sorgesu
            I think in the MAC version you just pull them away off the menu bar. Delete the icon for them from the menu bar.
            Susan Sorger
            Former Seller Hand Rendered Entourage
            Former Canadian Authorized Training Centre, SketchUp
              tomsdesk
              On PC's: whichever toolbars you have open when you exit the program will be open when you start the program the next time (template be damned)...mac?
              2.5D Trees & Shrubs!
              • AnssiA Offline
                Anssi
                Edson,
                I seem to remember that you are using a Mac. You might have a corrupt Preferences (Plist) file, or something awry with your disk permissions. Just citing things read, no Mac near to check.
                Anssi
                • EdsonE Offline
                  Edson
                  susan,
                  yes i can do that but i am not talking about getting rid of individual tools.
                  tom,
                  so i thought but it is not working.
                  anssi,
                  i will look into it.
                  meanwhile, have a look at the picture to see that all scripts that come with a toolbar is represented there.
                    sorgesu
                    some of those tools are from rubi extensions.
                    Under your menu item : SketchUP>Preferences>Extensions turn off the extensions that pertain to thes ruby scripts. It will tell you that it can't do it right away. ALso make sure that the tool bar pertaining to that extension is closed. You need to close SketchUp and start again and now that the extension is disable, it should no longer show up
                    Susan Sorger
                    • EdsonE Offline
                      Edson
                      thanks, susan. it worked for the ones which were listed there. some others, like Joint Push-Pull and Renditioner, which were not, keep reappering without being invited.
                        sorgesu
                        Edson, I expect that since those are all ruby add ons that perhaps the programming, especially with respect to MAC, may be flawed.
                        Susan Sorger
