    [Plugin] 3d Shapes Tool (was: Pyramid Tool)
    53 Posts 21 Posters 50.4k Views 21 Watching
      Macs
      @cphillips said:
      Loving the plugin dude!
      Suggestion. Once you place the shape it is hard to set the height. You need to have something to infer the height and if nothing is available it is frustrating. My solution was to add a construction line to the center of the shape after the second click.
      [CUT]
      Strange.. on my system my tool works differently 😞
      when you do the second click with the cone tool it goes up
      and down with the height without being locked on the surface.
      I have to review the code to see if I made some mistrake invocking
      some method without "self.".
      thank you for the suggestion on the costruction line, I'll think about it.
        CPhillips
        I figured this out. In my case I build a lot of shapes on a big floor plane. When I draw a cone it infers the height from the floor. I don't think this is a flaw in your plugin. But the construction line is still useful in many cases.
        • urgenU Offline
          urgen
          ....Please wait ....will be OK! 😉 😄 ..
          --pupil forever...------
            Macs
            You are right!
            I've adde the construction line feature ( ripped from your tool 😄 )
            It will be available in the next release, thank you.
            • urgenU Offline
              urgen
              Scripts is ready 😉 , problems of translation(russian-english) 🤣
              • urgenU Offline
                urgen
                ...This is both very interesting and useful topic 👍 …I wonder why the founders of SKETCH-UP haven’t done the 3d shapes (primitives) earlier 😕 …If we have raised such an issue and this caused that much interest, we have to finish it up… ❗ I am not a script man, although many people say I would be capable of doing that quite a bit…unfortunately, quite poor knowledge of English and the tough schedule do not let me study RUBY in more details…I had a choice to make here: to draw or to write…I have chosen the 1st one…However, I do get the processes in scripts and can freely apply some changes for my personal convenience in my usage but not more than that…I quite like the style of painting the figures in SketchyPhysics ( Chris, I really appreciate it!) and the MACS style too… I have selected the files responsible for SHAPES building (from SketchyPhysics) and have made a decision to turn for help to one amazing Russian man Sahi (you possibly remember his name from the script “building a house”). In a few hours I got a response you can see below… 😄 …This is a Russian version and not everything works ideally, but much respect for his talent…he does not know English, but still manages to write English RUBI (imagine yourself writing RUBI in Russian or Chinese, which you do not know!!)… ..The many people the many minds, but the last thing I want is him to be remoted from the forum….thank you Sahi one more time! 😍 .....all the parameters of the letters are ascribed with the help of the keyboards…very convenient! 👍 ...MACS, I think that would be useful for you…And Chris---a comfortable supplementary for your SketchyPhysics. 😉
                SketchyPhysicsShapes.zip
                  CPhillips
                  Thanks for doing that Urgen. But I recommend this only be used for reference. There is still a fair amount of physics stuff in there. And it that could conflict with future versions of SketchyPhysics.
                    CPhillips
                    I noticed you have the same problem I did when creating spheres. I was never able to figure out why they were sometimes reversed. I wound up doing my own sphere routine.
                    What other shapes do you plan to support?
                      sahi
                      Corrected some errors
                      SketchyPhysics_1.zip
                        lapx
                        Can parametric tool be added this. After or during adding shape you can change radius or height parameters. VCB stuff you know. Now this would be fantastic!!! 😎
                          Macs
                          I've noticed is if you draw on a back face, the cone is reversed,
                          and for the sphere depends on the order of the edge passed to the add_face
                          on the first face created. For the cone the first face is the base, so if it's
                          draw on an existing back face, all the cone became backfaced.
                          For other shapes i've just finished the regular dodecahedron (the last platonic solid missing!)
                            Macs
                            VCB is fully supported by 3D shapes tool, read low-right corner hints.
                            • urgenU Offline
                              urgen
                              ...Thanks,SAHI! 😄
                              MACS,don,t stop your work! 🎉
                              • JClementsJ Offline
                                JClements
                                Hi Macs:
                                Request to add drawing an equal-sided cube (or maybe elongated one also?) from the center of the first mouse-click. If there was a way to alternate to starting from a corner that would be cool, but not essential.
                                And, since SU's rectangle tool doesn't have an option to create a rectangle from its center, this cube tool could also be used to do this by simply not moving the mouse along a third-axis for the 3rd mouse-click (or by double-clicking on the 2nd mouse-click).
                                Regards, John.
                                  CPhillips
                                  @jclements said:
                                  Hi Macs:
                                  Regards, John.
                                  I like the idea of a center version of shapes. How a shape (or even a line) is centered would be a great option at almost every step in the process. I was thinking that the CTRL key could toggle whether that state (width,height,depth) of the shape is centered or not. That is sort of how the sphere in the SketchyPhysics solids work.
                                    OFFTOPIC:
                                    Mirror.rb script hands and can also copy the objects if desired - like ACAD...
                                      JClements
                                      Chris, I agree. This would be consistent with other SU tools such as the Scale tool.
                                      OFFTOPIC:
                                      1. A big gripe of mine is being able to scale from the center of a selection along ONLY TWO AXIS directions with one mouse-drag sequence or one entry in the VCB. Primarily at equal distances from the center. I am wondering if some of the coding included in these new hybrid tools could utilized to create such a script?
                                      2. Also, when Dragging a side selection handle, you mirror or "flip" an object. However, manytimes I'd like to COPY the flipped object. In some of my 2d apps when dragging an object with the left-mouse depressed, I can drop a copy by clicking and releasing the right-mouse buttom while the left is still depressed. I think this would be a good solution for a similar SU flip-and-copy script.
                                        pav_3j
                                        ah very neat lil ruby there. thank you for the hard work.
                                        pav
                                        Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                                          Macs
                                          I've finished the work on icosahedron too,
                                          now I will try to implement feature you all request and clean the code a little.
                                          see you next week.
                                            agrazdi
                                            Is it possible to assign a shortcut key to " create a Box " for instance.?
                                            • 3 / 3
