    Just Released! Subdivide and Smooth
    extensions
    102 Posts 36 Posters 26.0k Views 36 Watching
    • W Offline
      Whaat
      @pixero said:
      Is it possible to have the extrude tool select faces by hovering just like the push pull tool?
      No, this is not possible. If you assign a shortcut key to the extrude tool, you can hover over a face and then press the shortcut key to extrude. It works well.
      Thanks for purchasing!
      • W Offline
        Whaat
        Coen has kindly opened a forum exclusively for support for 'Subdivide and Smooth'. Please direct your questions and comments there.
        Please start a new topic for each independent question (and provide a detailed subject line...not just "Question" or "Help")
        • O Offline
          osx59
          hello Whaat,
          I bought script, but it does not function on my macbook 2,2 Ghz and 4Go fo mem !
          on Sketchup Pro 6.0 (6.4.245)
          V
          • chippwaltersC Offline
            chippwalters
            I tested it on my MacBook without issue. I used the free version of SU6. I did not use Smustard installer as I was a beta tester.
            Currently working with Cross-Reality technologies
              chippwalters
              Here's another quick tute on creating a soft pillow in SketchUp using SubSmooth.
              http://www.gadgetplugins.com/chippstuff/pillow.jpg
              Note: edited to update link to slower playing animation.
                chippwalters
                @kwistenbiebel said:
                Both the flash animations posted on this page seem to play at a really fast speed, making it impossible to follow what's going on. Is it just my PC, or is this intended? The speed prevents me from learning things about the plug.
                I updated the pillow tutorial so it plays back at normal speed.
                http://www.screencast.com/t/R49fSwlJge
                  kwistenbiebel
                  @jorgensen said:
                  Strange. If I have VRAY for SU loaded I can't use SubSmooth. The object simply turns black when I select "Subdivide and Smooth".....
                  Any ideas what can be the problem ?
                  Jorgensen
                  Hi Jorgensen,
                  I haven't bought the wonderful plugin yet (a helpful hand on this forum will buy the plugin for me as I don't have a credit card) but you might want to check your Internet explorer settings.
                  If the plugin has web based panels (not sure though) the Vray plugin might screw things up at the level of your IE.
                  I had this problem with Skindigo earlier and a hard reset of the IE settings solved it ('advanced options').
                  Try it and if it won't work,maybe Whaat can be of assistance...
                  Cheers and I can't wait to try Subsmooth.
                  Kwistenbiebel
                  • PixeroP Offline
                    Pixero
                    And what about hiding the proxy?
                      Jorgensen
                      It would be great if one could select the layer for the proxy in an dropdownmenu.
                        chippwalters
                        To hide the proxy, you can duplicate the proxy subGroup, then move it out of the group with the proxy. Then hide the proxy group and use the duplicated subGroup.
                          Jorgensen
                          Turn off a layer would be easy 😄
                          • PixeroP Offline
                            Pixero
                            I agree and hopefully it will be implemented. 😉
                              krash88
                              Great script! I love the features, but I've had a problem with the knife tool. If I use it to snap to an endpoint, the resulting "cut" doesn't actually start at that endpoint. I think these images will explain what I mean.
                              http://i109.photobucket.com/albums/n65/krash88/knife1.jpg
                              http://i109.photobucket.com/albums/n65/krash88/knife2.jpg
                              I've had no other problems so far and I see this one tool, in particular, speeding up my work considerably, if I can get it to work properly.
                              Thanks again and thanks for any help!
                                remus
                                Krash, it should work if you go in to parallel projection mode.
                                • jenujacobJ Offline
                                  jenujacob
                                  i think he was in parallel projection as shown in the first image....
                                    remus
                                    I tried it in parallel projection and perspective and i could only replicate the problem in perspective 😉
                                      krash88
                                      That was in parallel projection mode...
                                        remus
                                        My bad, where you in a specific view (top, bottom, left etc)? if notits worth trying that, as ive found that can also cause problems.
                                          krash88
                                          I've tried it every way that I can imagine; top, front, side, perspective, on every type of geometry; flat 2d, 3d cubes, etc. It always offsets the cut when I try to snap it to an endpoint. I hope this can be a quick fix(hopefully I'm just doing something wrong). My employer is, as well as myself, VERY impressed with what this script can do and I'm itching to finish my first model!
                                            Masta Squidge
                                            Oh hell I bought it. I havent even used SU in like three weeks and I bought it anyways lol.
                                            Maybe ill have more incentive to play with SU.
                                            • 4 / 6
