ℹ️ GoFundMe | Our friend Gus Robatto needs some help in a challenging time Learn More
Scaling a Layout PDF
Scheduled Pinned Locked Moved LayOut Bug Reporting
layout
4 Posts 3 Posters 10.2k Views
  • G Offline
    Gareth
    layout looks great on a PDF.....but scaling is not even close to being accurate even after I have slected the scale
    anyone else having this problem???
    any suggestions
    Cheers,
    Gareth
      Charlie__V
      Gareth,
      I too had some difficulty initially with scaling in Layout.
      I am assuming you are talking about your SU model scale.
      A couple points:
      Make sure scale remains as desired, after any adjustments to model view.
      Make sure view is Parallel Projection.
      Oh...& make sure printer is not resising to fit page.
      Beyond this I would really be guessing.
      Can you post files?
      Charlie
      • G Offline
        Gareth
        Hi Charlie,
        Actually the problem is when I draw a Site Plan, or Floor Plan. A Model doesn't concern me because it is more a matter of sizing it proportionbally on the Layout page.
        An example would be if I import it it into Layout and set the scale of say 1:100 for a Floor Plan or 1:200 for a Site Plan.
        It should be simple, but when I print the PDF, the scale is quite different from the scale I have selected....even though it looks nice...!!
        Cheers,
        Gareth
          jhauswirth
          Can you attach some skp file(s), layout file(s) and pdf file(s) that demonstrate this problem?
