    Scaling a Layout PDF
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    4 Posts 3 Posters 10.3k Views 3 Watching
    • GarethG Offline
      Gareth
      layout looks great on a PDF.....but scaling is not even close to being accurate even after I have slected the scale
      anyone else having this problem???
      any suggestions
      Cheers,
      Gareth
        Charlie__V
        Gareth,
        I too had some difficulty initially with scaling in Layout.
        I am assuming you are talking about your SU model scale.
        A couple points:
        Make sure scale remains as desired, after any adjustments to model view.
        Make sure view is Parallel Projection.
        Oh...& make sure printer is not resising to fit page.
        Beyond this I would really be guessing.
        Can you post files?
        Charlie
        • GarethG Offline
          Gareth
          Hi Charlie,
          Actually the problem is when I draw a Site Plan, or Floor Plan. A Model doesn't concern me because it is more a matter of sizing it proportionbally on the Layout page.
          An example would be if I import it it into Layout and set the scale of say 1:100 for a Floor Plan or 1:200 for a Site Plan.
          It should be simple, but when I print the PDF, the scale is quite different from the scale I have selected....even though it looks nice...!!
          Cheers,
          Gareth
            jhauswirth
            Can you attach some skp file(s), layout file(s) and pdf file(s) that demonstrate this problem?
