    Grip curve..How?
    6 Posts 4 Posters 1.4k Views 4 Watching
      3eighty
      In the attached picture the arrow points to a small inset where the side of the thumb fits...How can I make this inset and make it loof natural and smooth..?
      Thank you..
      • GaieusG
        • bezier curves + skin.rb
        • arcs + skin.rb + scale tool...
          tedious for sure... πŸ˜’
        • R
          remus
          you might be able to do a cylinder and then intersect it, followed by another intersection to get the shape across the top. would need a fair bit of cleaning up afterwards, but should give you the general shape.
            3eighty
            My thanks to both of you..
            • monsterzeroM
              monsterzero
              3eighty, I'll be doing a similar stock for a shotgun in about a month. I'll be using the same technique that I employed with my flying wing (http://www.youtube.com/watch?v=QO_D3ltOilk)
              • Draw out a section of the stock (similar to the fuselage in the wing video).
              • Draw out the profile of the entire section of the model.
              • Pull the section along the profile sizing the section as I go along.
              • Go back and tweak the individual vertices to push in the bevel of the grip curve.
              You could probably do it faster with skin.rb or soap bubble, but I don't usually use those scripts. I guess I like the control I get for certain shapes, that comes from modeling a few people in SketchUp.
              monsterzero
              I live stream my work on my graphic novel:
              https://www.youtube.com/@monsterz3r0
              http://infinitemachine.tv/
              https://www.aaatitle.xyz/
                3eighty
                monsterzero> A dbl side by side old stage coach shotgun is what Im trying to make..What are you going to make? Thanks for the video..You should know that it would help to be on speed to watch it, it's so fast..πŸ˜„
