    Quarter Sawn Oak texture
    31 Posts 11 Posters 10.7k Views 11 Watching
      Here are three variations of a quarter sawn oak texture. Thanks to Modelhead for converting the lousy JPG I gave him into something very usable.
      Quarter Sawn Oak.skp
      • boofredlayB
        boofredlay
        Nice. I can use these. πŸ˜„
        • M
          mike d
          very nice thanks
          mike d
          The grass is always GREENER on the roof.
          • A
            alan wood
            What beautiful grain. Thanks for that
            cheers
            Alan
            • I
              itisonlyi
              Forgive my obvious ignorance. Being new to Sketchup, and even newer to this Forum, I am probably missing something incredibly obvious, but...
              How can I use this image as a texture, or material, in Sketchup?
              Steve
              • R
                remus
                If you open up the model, go into the materials window (window->materials) and then select 'in model' from the drop down menu, you'll see a list of the textures in the model, you thn right click these and select 'save as' to save the material.
                • I
                  itisonlyi
                  AaaaaH! I see.
                  And I see I can do that with imported jpg's that I use as textures as well.
                  Is there some easier way to save many Jpg's to textures? By the batch? I have a few dozen images I would like to do that with.
                  Many thanks (and such a swift response!)
                  Steve
                  • R
                    remus
                    sorry, i cant help you with importing jpgs in batches, although i'd be interested to see if there is a method for doing this, ive got a lot of jpg textures just waiting to be used.
                    • I
                      itisonlyi
                      Thanks for the response.
                      If I find something I will certainly post it here.
                      Steve
                      • K
                        KennyL
                        Remus,
                        There's a Ruby script called massmaterialimporter.rb that will do what you want.
                        See http://www.crai.archi.fr/rubylibrarydepot/ruby/em_ren_page.htm.
                        Ken
                        Clothes make the man. Naked people have little or no influence in society.
                        • I
                          itisonlyi
                          @kennyl said:
                          Remus,
                          Thanks. I had found that a few minutes ago, but can't figure out how to make it work.
                          It prompts me to open a file, which it says will open the folder. I do so, and nothing further happens.
                          Any suggestions gratefully received.
                          Steve
                          • K
                            KennyL
                            Start the material importer, navigate to the directory containing your jpg images, click on any one of them and then click the Open button. After a bit, new materials will be added to your 'In Model' library.
                            Ken
                            • I
                              itisonlyi
                              Yes, but they do not appear to be saved as skm files.
                              Each must be saved individually.
                              Or am I just being dense?
                              Steve
                              • K
                                KennyL
                                You need to move each new material from the 'In Model' library to either an existing material library or to a new one. I suggest that you read up on the Material Browser in the SketchUp User's Guide which explains the whole process.
                                Ken
                                • I
                                  itisonlyi
                                  So you do have to handle each file individually.
                                  There is no way to "select all" and move/drag/copy to another folder/library.
                                  But I am way better off with this plugin than I was before. Thanks for it.
                                  Steve
                                  • I
                                    itisonlyi
                                    I got this excellent advice in the Google Group Sketchup forum
                                    http://groups.google.com/group/sketchup/
                                    ...there's a dropdown menu pick called Save Library As...
                                    That will save your entire In-Model Material Library as a named
                                    library, like Wood or Carpet and Textiles. The new library will
                                    correspond to a like-named folder under C:\Program Files\Google\Google
                                    SketchUp 6\Materials, and the folder will contain one .skm file for
                                    each texture.
                                    Hope others find it useful
                                    And thank you again for your help
                                    Steve
                                    • R
                                      remus
                                      cheers, thats very useful, i was just going to do it by dragign all the materials into their respective folders πŸ˜›
                                      • O
                                        oldworld124
                                        I'm a Newbie here on Sketchup and Ruby Plugins.
                                        Could someone explain to me how to download this massmaterialimporter.rb Plugin? When I go into the Plugins library and click on this Plugin it comes up with script. Is there a way to download it normally or do I need to do it some other way. I would like to set up a materials library and do not know how.
                                        Thanks, John
                                        • A
                                          Aidus
                                          Wow! Amazing textures! Thanks!
                                          CPU: Intel Core i7 Extreme Edition 965
                                          RAM: OCZ Gold DDR3 1600MHz 12Gb
                                          Video: Asus Radeon HD4870 X2 2Gb
                                          Mobo: Asus P6T Deluxe 1366 Intel X58
                                          • GaieusG
                                            @oldworld124 said:
                                            ...Could someone explain to me how to download this massmaterialimporter.rb Plugin...?
                                            Hi John,
                                            Yes, ruby files are simple text files (only difference is the *.rb extension vs. the *.txt extension). Web browsers and text editors therefore handle both the same way. Anyway, there are two easy ways to save them:
                                            1. Right click on the file and "Save as..." (or something like that in different browsers) into the Plugins folder. Make sure to give it the same name as it is written on the download page and add the .rb extension (in case it is not added automatically).
                                              NEVERgo to File > save page as... in your browser because it will add a whole bunch of html codes to the text file and it will get corrupted.
                                            2. When you have already clicked on it and the text is opened in your browser, select all (Ctrl A) > Copy (Ctrl C) and paste it (Ctrl V) into a plain text editor (like Notepad - NEVER a Word processor like MS Word or such!!!).
                                              Now save it (with the same naming rules as above) into your Plugins folder.
                                            • 1 / 2
