    Quarter Sawn Oak texture
    31 Posts 11 Posters 9.7k Views 11 Watching
      alan wood
      What beautiful grain. Thanks for that
      cheers
      Alan
      • I Offline
        itisonlyi
        Forgive my obvious ignorance. Being new to Sketchup, and even newer to this Forum, I am probably missing something incredibly obvious, but...
        How can I use this image as a texture, or material, in Sketchup?
        Steve
          remus
          If you open up the model, go into the materials window (window->materials) and then select 'in model' from the drop down menu, you'll see a list of the textures in the model, you thn right click these and select 'save as' to save the material.
          • I Offline
            itisonlyi
            AaaaaH! I see.
            And I see I can do that with imported jpg's that I use as textures as well.
            Is there some easier way to save many Jpg's to textures? By the batch? I have a few dozen images I would like to do that with.
            Many thanks (and such a swift response!)
            Steve
              remus
              sorry, i cant help you with importing jpgs in batches, although i'd be interested to see if there is a method for doing this, ive got a lot of jpg textures just waiting to be used.
              • I Offline
                itisonlyi
                Thanks for the response.
                If I find something I will certainly post it here.
                Steve
                  KennyL
                  Remus,
                  There's a Ruby script called massmaterialimporter.rb that will do what you want.
                  See http://www.crai.archi.fr/rubylibrarydepot/ruby/em_ren_page.htm.
                  Ken
                  Clothes make the man. Naked people have little or no influence in society.
                  • I Offline
                    itisonlyi
                    @kennyl said:
                    Remus,
                    Thanks. I had found that a few minutes ago, but can't figure out how to make it work.
                    It prompts me to open a file, which it says will open the folder. I do so, and nothing further happens.
                    Any suggestions gratefully received.
                    Steve
                      KennyL
                      Start the material importer, navigate to the directory containing your jpg images, click on any one of them and then click the Open button. After a bit, new materials will be added to your 'In Model' library.
                      Ken
                      • I Offline
                        itisonlyi
                        Yes, but they do not appear to be saved as skm files.
                        Each must be saved individually.
                        Or am I just being dense?
                        Steve
                          KennyL
                          You need to move each new material from the 'In Model' library to either an existing material library or to a new one. I suggest that you read up on the Material Browser in the SketchUp User's Guide which explains the whole process.
                          Ken
                          • I Offline
                            itisonlyi
                            So you do have to handle each file individually.
                            There is no way to "select all" and move/drag/copy to another folder/library.
                            But I am way better off with this plugin than I was before. Thanks for it.
                            Steve
                            • I Offline
                              itisonlyi
                              I got this excellent advice in the Google Group Sketchup forum
                              http://groups.google.com/group/sketchup/
                              ...there's a dropdown menu pick called Save Library As...
                              That will save your entire In-Model Material Library as a named
                              library, like Wood or Carpet and Textiles. The new library will
                              correspond to a like-named folder under C:\Program Files\Google\Google
                              SketchUp 6\Materials, and the folder will contain one .skm file for
                              each texture.
                              Hope others find it useful
                              And thank you again for your help
                              Steve
                                remus
                                cheers, thats very useful, i was just going to do it by dragign all the materials into their respective folders πŸ˜›
                                • O Offline
                                  oldworld124
                                  I'm a Newbie here on Sketchup and Ruby Plugins.
                                  Could someone explain to me how to download this massmaterialimporter.rb Plugin? When I go into the Plugins library and click on this Plugin it comes up with script. Is there a way to download it normally or do I need to do it some other way. I would like to set up a materials library and do not know how.
                                  Thanks, John
                                    Aidus
                                    Wow! Amazing textures! Thanks!
                                    CPU: Intel Core i7 Extreme Edition 965
                                    RAM: OCZ Gold DDR3 1600MHz 12Gb
                                    Video: Asus Radeon HD4870 X2 2Gb
                                    Mobo: Asus P6T Deluxe 1366 Intel X58
                                      @oldworld124 said:
                                      ...Could someone explain to me how to download this massmaterialimporter.rb Plugin...?
                                      Hi John,
                                      Yes, ruby files are simple text files (only difference is the *.rb extension vs. the *.txt extension). Web browsers and text editors therefore handle both the same way. Anyway, there are two easy ways to save them:
                                      1. Right click on the file and "Save as..." (or something like that in different browsers) into the Plugins folder. Make sure to give it the same name as it is written on the download page and add the .rb extension (in case it is not added automatically).
                                        NEVERgo to File > save page as... in your browser because it will add a whole bunch of html codes to the text file and it will get corrupted.
                                      2. When you have already clicked on it and the text is opened in your browser, select all (Ctrl A) > Copy (Ctrl C) and paste it (Ctrl V) into a plain text editor (like Notepad - NEVER a Word processor like MS Word or such!!!).
                                        Now save it (with the same naming rules as above) into your Plugins folder.
                                      • O Offline
                                        oldworld124
                                        Hello Gaieus,
                                        Thanks for the reply. However, I tried saving massmaterialimporter.rb into the Plugins section of Google SK7 and it does not show up. I must be doing something wrong. I copied and pasted in Notepad as you explained and named everything correctly and saved it in Plugins. The Folder does not show up at all. I then saved it in My Documents to see if it would show up. It does but only opens in Excel. The script is the same as is on the site. Your help and any from others is much appreciated.
                                        Thanks, John
                                          It mightnot show up in the Plugins menu but somewhere else (I don't have it so don't know).
                                          It's interesting though that it opens in Excel. Can you open it in Notepad? Do you see any strange in the text if you open it?
                                          • O Offline
                                            oldworld124
                                            I have been able to copy and save it to Notepad and reconfigured it to open in Notepad
                                            instead of Excel. The problem is that I cannot get it to go to SKP7
                                            Plugins. It only opens in Notepad and is in it's proper script as is shown on the Ruby Library. It will not go into Plugins on SK7. Am I copying too much? Could someone please give me some pointers as to how to get this to run? It seems like a very useful Plugin. I am a quick learner. I just needs some pointers.
                                            Thanks, John
