    Dimensioning
    4 Posts 3 Posters 741 Views 3 Watching
    • M
      mk11
      Problem: After extruding walls in a building i want to dimension interior and exterior walls and openings, but but my dimensions appear "on top" of the extruded walls instead of on the floor plane. How can i insert dimensions on the floor plane after walls have been extruded?
      Thanks,
      mk
      Marc Kleinmann
      SU Pro 2015
      Mac & Win
      • M
        mk11
        But how can i add the new ones so they will appear on the floor plane?
        Marc Kleinmann
        SU Pro 2015
        Mac & Win
        • J
          Jim
          Dimensioning is a little weak in SketchUp. You can move Dimensions using the Move Tool. The other option is to delete and add new ones.
          There are a few Dimension settings in the Window > Model Info > Dimensions menu.
          • R
            rhankc
            mk11,
            I found my quickest work thru was to place a line from the exterior centerpoint of the opening that was above the floor plane down (blue) to the floor, this was my pick point for dimensioning. Mostly I deleted them at the next ISO view, but if you place them in their own layer, you can use them again.
            I like the dimensioning capabilities of SU. It is extremely flexible,stable and easy to modify, and with a little technique modification on my part it is quite easy to dimension a plan to my tolerances.
            Regards,
            Hank
