    RPS3D PDF portable
    extensions
    8 Posts 3 Posters 2.7k Views 3 Watching
    • BurkhardB Offline
      Burkhard
      I`m interested to see a portable version of RPS 3D PDF.
      Is it possible?
      Burkhard
      http://www.ia-plus.de
        richcat
        Hi Burkhard
        By portable I presume you mean could it ported to be made to work on a Mac.
        I've had a look at the RPS Forum and RPS Wiki, but no luck there.
        I'm sure Al Hart will soon see this and give you a definitive answer as he is really the only person who could tell you. 😉
        Richcat
        • BurkhardB Offline
          Burkhard
          Not really MAC, more to take it with me on an USB stick for using it at different situations. ( No installation on a desktop PC ). 😛 Thanks for the response.
          • BurkhardB Offline
            Burkhard
            Get it! solved 😮
              richcat
              Hi Burkhard
              If you don't mind I have copied your original post over to the RPS forum in the 3D PDF Forum
              Richcat 😉
              • Al HartA Offline
                Al Hart
                Re MAC Version
                RPS does not plan any MAC versions of its Plug-ins at this time.
                Al Hart
                http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
                IRender nXt from Render Plus
                  richcat
                  Thank Al 😄
                  Richcat
                  • Al HartA Offline
                    Al Hart
                    Re MEMORY STICK
                    This should be possible. You should be able to copy the contents of C:\Program Files\Render Plus Systems\3D_PDF onto a memory stick, place it into a computer and run skp_to_3d_pdf.exe from the memory stick.
                    We will give it a try.
                    However, I can think of a few problems.
                    1. Some Visual Studio DLL's may not be on the target computer.
                    If we discover what they are, then they can be copied onto the memory stick and that may work (or we may have to create a new release of 3D PDF with the missing DLLs)
                    1. You will not be licensed to run RPS 3D PDF on the target machine.
                    I don't know how we will solve this problem. We can discuss it after you get the comcept working properly.
                    There are 2 other solutions to the general problem.
                    1. You can "remote log in" to your own computer, which is licensed for RPS 3D PDF from the client machines, run RPS 3D PDF remotely, load a file from the client machine and process it.
                    2. You can bring your portable computer with you to the client location, put the .SKP file from the client machine onto your portable, and use your portable to create the PDF file.
                    Al Hart
