    How to make a mess in SU
    4 Posts 2 Posters 848 Views 2 Watching
    • R
      rhankc
      Man did I ever screw up.
      I made these components knowing and when I brought them into my drawing I wanted them scaled up x4. Now the problem is...the dimensions think they get to 4x themselves and the text stays at the made size which was made 1/4 of the intended finished size. I have a big dimension value and a little bitty text.
      The arrow text did the same thing, (stayed small) I made it 1/4 size for scaling and when I scaled the detail, It stayed small.
      This is the opposite of what I expect to happen.I need an explode Dimension tool. Does anyone have one?
      Life is too short to fight computers.
      Hank
      • GaieusG
        Hank,
        Did you scale with the tape measure tool? AFAIK that does not scale imported geometry (for some funny reason) but maybe this was changed in SU6.
        (Maybe I just don't understand you at all πŸ˜’ )
        • R
          rhankc
          Actually, I used the Scale tool.
          The tape measure tool kept moving my assembly around the screen but there was no decipherable difference in the size.
          Edit: I thought there was a explode the dimension tool, so I could make it stay at its current value then after the change, it would still be the same numeric value.
          TGIF
          Hank
          • GaieusG
            OK now I understand I think.
            How about going to (Window) > Model info > Dimensions and editing the font size there?
            Dimension and text label features are ruled model level and you cannot "scale" them...
