    Cast shadow from transparant face?
    4 Posts 2 Posters 734 Views 2 Watching
    • B
      bravilor
      Can someone please explain some things about casting shadows from transparant faces?
      Sketchup-help function says transparent surfaces only cast shadows above 70% opacity but how can you explain this:
      Both 'bryce' and the cube are painted with the same material at 25% opacity, both are components with 'cast shadows' turned on and yet the cube does not cast shadows...
      What am i missing here? Thanks in advance πŸ˜„
      • GaieusG
        Well, the case is that neither should cast shadows... Bryce is the curious thing here... 😲
        Are both sides of Bryce painted? with this transparent material?
        • B
          bravilor
          yes, both sides are painted...
          here's the skp to check:
          Untitled.skp
          weird ❓
          • GaieusG
            Still it's got something to do with the "face me" property - if you uncheck that, Bryce won't cast shadows either and vice versa - if you check that for the cube, it will also cats shadows.
            Still weird why a face me component should behave differently.
