    Page layout styles
    8 Posts 6 Posters 4.2k Views 6 Watching
    • Paul RussamP Offline
      Paul Russam
      I dawned on me that I could use styles to help with picking a view.
      What I've done here is to create a PNG that is A3 in size/proportion with a 20mm boarder. I've divided it vertically and horizontally into 3rds (rule of 3rds) and popped in a couple of diagonal lines.
      The style is the default SU settings with the image as a watermark over the model space.
      My intention is to use it to pick/setup the view then switch to another style before saving the view.
      I've attached both A3 landscape and A3 portrait.
      A3L-20b.style
      A3P-20b.style
      Paul Russam
      English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
        Jackson
        It sounds innovative- is this to allow you to export images to scale at specific paper formats or is it to allow easier/better artistic composition of images?
        Jackson
          Paul Russam
          More about getting the composition right, trust me I need all the help I can get.
          Paul Russam
            Jackson
            Ahh... I just rely on "if it looks right it is right" method.... for better or worse!
            Jackson
            • Mike LuceyM Offline
              Mike Lucey
              Thanks Paul, I'II have a look at these. Looks like an
              interesting idea.
              Mike
              • utilerU Offline
                utiler
                Hi Paul, just wondering how you did this....?
                Was it just a vector file that was saved as .png?
                Thanks in advance....
                Andrew
                Just Curious...
                  linea
                  This is interesting Paul, could it be used as a sort of scale paperspace?
                    stuartb
                    This is genius! And greatly helps me with similar I am experimenting with . . I am convinced that 'Layout' can be acheived within Sketchup itself . . .
