    Drawing lines tangent to a circle
    7 Posts 5 Posters 3.1k Views 5 Watching
      dammerel
      hi guys
      can a line be drawn tangent to a circle or what is the best way to fillet two lines
      thanks Andrew
      • G Offline
        Gidon Yuval
        Hi Andrew,
        Have a look at these two skippys. I think they answer you question.
        Cheers
        Gidon
        Tangent-1.skp
        Tangent-2.skp
        If you don't know where you're going, you're never going to get there.
        • W Offline
          watkins
          Dear Andrew,
          Drawing a line tangent to a circle is a little tricky as each circle is made up of a finite number of line segments (the default is 24). If you draw a circle and then use the line tool to draw a line touching the circle the inference engine will take you to either a segment end-point or a segment mid-point. If you snap to an end-point the line will turn magenta when your attached line is parallel to one of the line segments connected to that end-point. Strictly speaking (and for a 24 segment circle), to get a true tangent to the circle you should snap to a segment's end-point, draw the line parallel to that line segment and then rotate it 7.5 degrees about the end-point. Experiment!
          Hope this helps,
          Kind regards,
          Bob
          • Jean LemireJ Offline
            Jean Lemire
            Hi Andrew, hi folks.
            See attached SU file for ideas.
            Fillet between lines.skp
              Jean Lemire
              This is inspired by this site:
              http://www.mathopenref.com/consttangents.html
              Tangent to circle.skp
                dammerel
                thanks all for the replies..i now have lots of ideas..
                • Y Offline
                  yaza
                  Why complicate your life when the answer could be easy.
                  Draw a circle with any amount of edges.You now want to draw a tangent line to this circle.Chose any vertex, it connects two segments, go at the end of those and join them with the tape mesure tool, then slide a //guide line to your chosen vertex you now have a tangent.Et voila πŸ˜‰
