    Help with a design problem
    8 Posts 5 Posters 1.4k Views 5 Watching
    • D
      dammerel
      hi guys
      i hope someone can help with this,
      Have a look at the attached model -its a bike rack
      How would I model a gusset (plate) in the apex of the triangle legs
      so the horizonal bar can be welded to it
      I know i could draw it and then move it into position but it be
      done in-place ?
      Andrew
      • D
        dammerel
        BIKE RACK.skp
        • GaieusG
          Andrew,
          Nice that. Care with the fron/back colours though; you will have hardships with renderers once you want to try.
          BTW - have you read the announcement?
          • R
            rhankc
            I dont totally understand your question. But, start the component elsewhere; with a single line turned into this component. Then go to you apex and use the round material as your guide and draw your new element. After you apex element is started erase the stray line youstarted the component with. HTH
            Hank
            • ToboboT
              Tobobo
              Do you have an image of what you're trying to achive?
              Toby
              Philippians 4:13
              • W
                watkins
                Dear Dammerel,
                Is the attached the sort of thing you are looking for?
                Kind regards,
                Bob
                BIKE RACK2.skp
                • GaieusG
                  Ah, yeah, sorry guys. I first saw the attachment THEN the question in SEPARATE posts but before, I already answered (actually not knowing what the hack was) and was happy to be able to merge the two.
                  Kind of a bit tired nowadays with all this new board stuff.
                  Well, actually, Andrew, I don't see why you could not do it elsewhere and move it into place when done.
                  This is the normal way when in place there's a lot of disturbing, inferencing geometry.
                  • D
                    dammerel
                    thanks guys
