    Help required!
    2 Posts 2 Posters 574 Views 2 Watching
    • N
      not registered yet
      Hi there,
      I've attached a sketchup file which is my first attempt at something "organic", I've done quite a bit of architechtural stuff but I never done something with compound curves.
      The method I used was to get the basic shape by extruding plan, side and front views, drawing in a mesh and then filling the mesh by lacing lines together.
      The results aren't very good.
      I've decided to do the job over but I'd like some advice as to how I can improve the end product from you guys.
      Don't hold back - I need the truth!
      Chris
      EDIT: Sorry the file is too big - I'll have to think of something else!
      EDIT 2 - here's a jpeg!
      http://www.sketchucation.com/forums/scf/sas/Newbie/25nose.jpg
      P: chrisg
      • R
        robmoors
        Probably your textures are too big, try uploading the file without textures.
        Yes I see now, your plan and front and side textures are still in the model, get rid of those and you will be able to upload.
        Rob Moors
        Architecture Student
