    [Plugin] List Layers Colors
    8 Posts 4 Posters 7.7k Views 4 Watching
      ListLayerColors.rb
      Does what it says on the wrapper...PayPalButton
      ListLayerColors.rb
      • Dan RathbunD Offline
        Dan Rathbun
        Uses .obj file export functions.
        Will NOT work with Sketchup Free ver 7.1+, requires Pro version.
        I'm not here much anymore.
          I completely forgot that I wrote that !
          But it was three and a half years ago - when I didn't know what I was doing even more than I don't now [?] 😳
          It IS now Pro only because it uses OBJ export to find the colors - although probably there weren't even the two versions back then !
          Unfortunately the Pro/Free .dae exporter doesn't pick up color-by-layer so it can't be utilized.
          At least we do have some sort of a temporary layer.color 'get' for Pro users - though again it's pretty clunky πŸ˜’
            Dan Rathbun
            @dan rathbun said:
            Changes you might try:
            EDIT - PM'd you a renamed file with snippets added.
            SNIP(...removed code snppets...)
            • Miner_JeffM Offline
              Miner_Jeff
              Hello!
              Thanks for sharing this script. The ruby code gurus and their shared code are what make Sketchup and this site so vibrant.
              I realize it is several years old now.
              Any chance this could be changed/morphed to do the reverse? I used it to export the layer names and colors to a file. Now wish to import the layer list (creating layers in a new file ) and/or change layer colors to the rgb values in the file.
              Could also be useful for en masse layer color changes. I see it being useful to highlight a particular layer and setting colors on others to shades of grey and switching back to full color. I could see the list being changed programmatically using Excel VBA. I can hack my way through the VBA but ruby not so much. I would be willing to post the VBA code to the forum as a small repayment to the Sketchup community for all the free code and advice received over the years.
              Perhaps this deserves its own thread?
              Thanks & Cheers!
              Miner_Jeff
                @Miner_Jeff
                Here TIG-LayersFromList
                http://sketchucation.com/forums/viewtopic.php?p=566286#p566286
                  Miner_Jeff
                  πŸ‘
                  TIG:
                  Thank you so very much for the quick response and code!
                  Much appreciated!!
                  Cheers!
                  Miner_Jeff
                  • jujuJ Offline
                    juju
                    yep, TIG's a tiger when it comes to solutions and coding
                    πŸ˜›
