    Component question
    5 Posts 2 Posters 1.2k Views 2 Watching
    • I
      ianccc
      I created this component (link below)for our Local festival - I am in charge of signage and last year the plastic signs disinigrated so I an going to dust off the welder and make one to last
      http://sketchup.google.com/3dwarehouse/details?mid=b70347e4970a936ecec498144e458307
      Question can someone have a look and see if there are any real problems with my model - I relize there is some alighment + problems with the handle
      any info appreciated
      • I
        ianccc
        Yikkes - it's worse than I thought - I just downloded it off 3D warehouse
        I thought I re-saved the individual sign pickets with a different component name, what I am seeing is a jumble
        part of my component is always highlighted - is there a easy to unselect - not sure why this is happening
        ~ian
        • KrisidiousK
          Krisidious
          downloaded fine for me...
          to unselect either hit escape a few times or double click out in the open.
          By: Kristoff Rand
          • KrisidiousK
            Krisidious
            other than line up issues... like you said. all I would do is perhaps make a box for ballast at the bottom, or build it up more to weight it down.
            also the handle is a bit much for me... why not just put a grip around the pole at the middle... it's just for moving it right?
            otherwise... I'm sure this thing will last forever...
            By: Kristoff Rand
            • I
              ianccc
              thanks for the info - it worked I was able to
              un-select the component
              Yep - I will lose the handle and possible beef up the bottom plate with 1/2" steel
              thanks again
              ~ian
