    First Model & a Few Questions
    2 Posts 2 Posters 569 Views 2 Watching
      randallwise
      Thanks for all your input. I'm still not quite getting the component creating, I guess. If you look at the model again, there is a new component window, the super long one on either side of the top of the building. There are some windows that won't go translucent, and for some reason, the wall went off vertical on one side.
      Also, on the corner of the bulding with the recess portion, the roof is cut out. I can't figure out how to correct this. Something happened and I suddenly had angles everywhere and odd faces.
      I created the columns and then did used the 'intersect' tool to intersect w/ the model. Everything seemed fine until that corner, then my walls, roof, etc. were all funky.
      Any help is greatly appreciated!
      I'm getting the hang of this, I think!
      RSW
      Nutra_Ogden.skp
      P: randallwise
        tomsdesk
        Randall, I get the same model as before...no columns or new windows?
        I'll check again tomorrow.
        2.5D Trees & Shrubs!
