    Angles in Degrees
    17 Posts 5 Posters 4.1k Views 5 Watching
    • N
      not registered yet
      To All:
      I need to create a site plan from a survey. For accuracy, this will require entering the angle units in degrees, minutes and seconds. Is this possible in SketchUp? If so, how?
      Thanks in advance,
      Bill
      P: BillLen
      • KrisidiousK
        Krisidious
        yes it is... let me help... one sec.
        By: Kristoff Rand
        • KrisidiousK
          Krisidious
          Didier Bur has a few survey tools
          http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_arc_page.htm
          bottom of the page... Survey Tool.
          this should be perfect for you...
          also, in SketchUp you can import dwg files and other land survey format files, and all elevation data will be imported with it. meaning lines will come in at their real elevation
          By: Kristoff Rand
          • N
            not registered yet
            Thank you Kristoff. Just what the doctor ordered!
            P: BillLen
            • KrisidiousK
              Krisidious
              noooo problem.
              let us know if you need anything at all.
              By: Kristoff Rand
              • N
                not registered yet
                Hi Kristoof,
                Thanks for asking.
                I have downloaded and installed surveytool.rb, but it will only turn an angle of ninety degrees regardless of what numbers I input. I tried tuning off angle snaps, downloading and reinstalling the script, but it continues to insist on drawing lines at ninety degrees only. Any ideas?
                Also, it doesn't appear to draw curves.
                Thanks again,
                Bill
                P: BillLen
                • KrisidiousK
                  Krisidious
                  you prolly need to go into your file preferences and change the angle tolerance from 5 degrees to .1 or .01
                  try that and come back if it doesn't work.
                  By: Kristoff Rand
                  • N
                    not registered yet
                    Kristoff,
                    I don't see anything in Preferences that relates to setting angles. Under Windows - Model Info - Units, there is a place to set Angle Units - Precision, which I have set for 0.000 and I turned off Angle Snapping there as well. Still the problem persist. Sounds like there may be a bug in this script. Is this script working for you?
                    Bill
                    P: BillLen
                    • KrisidiousK
                      Krisidious
                      yes it works for me...
                      let me e-mail Didier...
                      By: Kristoff Rand
                      • jujuJ
                        juju
                        what I do is to create the site plan in my CAD software, then import it into SU and do a terrain model from that
                        • KrisidiousK
                          Krisidious
                          Didier must be on vacation or something...
                          let me make this bigger.
                          By: Kristoff Rand
                          • N
                            not registered yet
                            Hey Kristoff,
                            This is in reference to the link u posted:
                            There are a lot of awesome tools here that i really could use but every time i click on one of the links it directs me to a page containing the ruby script.... i could copy this into a text editor but how do i convert that into a ruby script?! I really dont know much about scripting so i'd really appreciate it if u could clear this one out fer me...
                            Thanx a million!!
                            P: iamjerine
                            • boofredlayB
                              boofredlay
                              Right click on the ruby script and save target as...
                              Save it here:
                              C:\Program Files\Google\Google SketchUp 6\Plugins
                              Then open SketchUp and start using your Rubies. Really simple.
                              Cheers.
                              • jujuJ
                                juju
                                be sure not to save a ruby script in apps like MS Word or the like since they add formatting and basically render the ruby useless. if you feel you have to open and edit something, do so with an app like notepad (simple text editor).
                                • N
                                  not registered yet
                                  oh hey im sorry i think i dint xplain the problem clear enough.... the thing is wenever i click on any one the links to rub scripts in "http://www.crai.archi.fr/RubyLibraryDep ... c_page.htm" it directs me to a page wich contains just text.... so after i copy all this text onto notepad how do i convert it from a ".txt" file to a ".rb" file before i copy it into the plug-ins folder?!
                                  thanx again!!
                                  P: iamjerine
                                  • GaieusG
                                    Simply just save as "rubyname.rb" i.e. just type the .rb extension after the name of the ruby (always save the ruby with the same name it originally has for it needs to get loaded and at the end of the script it even refers to this name).
                                    • N
                                      not registered yet
                                      awesome dude!!! thnx a ton man!! i think im gona hav a looott of fun now that i know that!! thnx again! πŸ˜„
                                      P: iamjerine
