    Look at face
    7 Posts 4 Posters 1.7k Views 4 Watching
    • D
      dammerel
      hi all
      While modelling, can you pick a face and "look at" it ?
      also what would be the best way to draw a series on hole on a diameter (P.C.D)
      Andrew
      • GaieusG
        Andrew,
        1. if you mean whether you can align your view to a face easily then yes. Right click on it and select "align view". this will orbit the camera perpendicular to the given face (now this does not work with curved faces though).
        2. I don't understand your question, sorry.
        • Jean LemireJ
          Jean Lemire
          Hi folks.
          See attached SU file for ideas.
          Note that this model is not drawn to any specific measurement but is given solely as an example.
          Holes rotation.skp
          • D
            dammerel
            PCD is like bolt holes around a tyre rim..
            sorry Im a mech. eng !
            • D
              dammerel
              ...and thanks for the answer
              Andrew
              • N
                nomicrowave
                Hi Andrew,
                I use the camera menu a lot. Camera, Standard Views, then pick which view you need. It's a quick and easy way to get to the side you need to see.
                Nomi
                • D
                  dammerel
                  thanks I actual think thats just as easy..Andrew
