🤑 30% Off | Artisan 2 on sale until April 30th Buy Now
Look at face
7 Posts 4 Posters 1.3k Views
    dammerel
    hi all
    While modelling, can you pick a face and "look at" it ?
    also what would be the best way to draw a series on hole on a diameter (P.C.D)
    Andrew
      Andrew,
      1. if you mean whether you can align your view to a face easily then yes. Right click on it and select "align view". this will orbit the camera perpendicular to the given face (now this does not work with curved faces though).
      2. I don't understand your question, sorry.
        Jean Lemire
        Hi folks.
        See attached SU file for ideas.
        Note that this model is not drawn to any specific measurement but is given solely as an example.
        Holes rotation.skp
          dammerel
          PCD is like bolt holes around a tyre rim..
          sorry Im a mech. eng !
            dammerel
            ...and thanks for the answer
            Andrew
            • N Offline
              nomicrowave
              Hi Andrew,
              I use the camera menu a lot. Camera, Standard Views, then pick which view you need. It's a quick and easy way to get to the side you need to see.
              Nomi
                dammerel
                thanks I actual think thats just as easy..Andrew
