    Ruby Challenge!
    26 Posts 8 Posters 4.2k Views 8 Watching
      RickW
      It's been a long time since there was a ruby challenge, so I thought I'd offer one.
      Kudos to the authors who can create a single-line "jukebox" that uses UI.play_sound(filename) to play all the sounds in the system sounds folder in sequence, with an indication of the file number and name. Each sound must be distinctly heard in its entirety without interruption from other system sounds or alerts. There is no penalty for using semicolons.
      The author who submits the shortest code will get extra kudos. 😄
      PM your solutions to me by noon GMT-6 Friday, 3 August 2007 for consideration.
      The length of the directory path will not be considered when checking the code length.
      RickW
      [www.smustard.com](http://www.smustard.com)
        todd burch
        Good challenge! Count me in.
        Todd
        • KrisidiousK Offline
          Krisidious
          I'm going to make this sticky for 7 days...
          good luck all... can't wait to see what you come up with...
          By: Kristoff Rand
            Jim
            Does SketchUp need to remain usable while the sounds are playing?
              RickW
              I don't see that as a requirement, but if you want to implement it, you may get extra kudos.
              The song number and title may be indicated anywhere you like, but if you use popup boxes, remember they often 'ding' when they appear, and that sound must not interfere with the track being played.
              RickW
                Jim
                It's the "without interruption from other system sounds or alerts" that's killing me.
                  RickW
                  Yes, it's definitely a challenge...
                  RickW
                    RickW
                    So far, we have three entries, all with distinct solutions. Only 3 days left to enter...
                    RickW
                      todd burch
                      Well, count me out. Didn't get to it. Next time!
                      Todd
                        RickW
                        Okay, here are the results, sorted by order of submission, path-coded for Windows XP:
                        @rickw said:
                        147 characters, 5 semicolons
                        (f=Dir["C;/Windows/Media/*.wav"]).sort!;i=0;t=UI.start_timer(3,true){puts "#{i}; #{f[i]}";UI.play_sound(f[i]);i+=1;UI.stop_timer(t) if i>=f.length}
                        110 characters, 5 semicolons
                        fn=0;d="c;/Windows/Media";Dir.foreach(d){|s| fn+=1;UI.play_sound(File.join(d,s));puts "#{fn}; #{s}";sleep(2)}
                        @tig said:
                        114 characters, 2 semicolons
                        Dir.chdir(d="C;/WINDOWS/Media/");(c=Dir['*.wav']).each{|w|UI.play_sound(d+w);UI.inputbox([w],[c.index(w).to_s],d)}
                        @jim said:
                        258 characters, 18 semicolons
                        @f=Dir["c;/windows/media/*"];def b(i);io=open(i,"rb");io.pos=28;b=io.read(4);io.close;b.unpack("i")[0].to_f;end;def j;t=0;@f.each_with_index{|s,i|;UI.start_timer(t){;Sketchup.set_status_text"#{i+1};#{s}";UI.play_sound(s);};t+=(File.stat(s).size/b(s));};end;j
                        Kudos to Thicket for the shortest code!
                        Honorable mention to TIG for second-shortest by 4 characters.
                        Kudos to Jim for checking the filesize to get the delay time!
                        Kudos to TIG for a really clever way of presenting the track info and avoiding both sound overlaps and system sound intrusion!
                        Now, for the follow-up challenge:
                        Create the jukebox with less than 100 characters! Entries due by noon (GMT-6) on Monday, 6 August 2007. Short challenge, but the hard work's been done 😄
                        RickW
                          todd burch
                          Here's mine:
                          iTunes
                          What do I win? 😆
                            RickW
                            Good effort, but you didn't use the UI.play_sound(filename) method. 😆
                            I'm also a bit worried if you put your system sounds into iTunes 😉
                            RickW
                              Jim
                              I was curious about the behavior of UI.play_sound. On my system, window 2000 pro, I wrote the core of the challenge as follows:
                              Dir["c;\winnt\media\*"].each {|s| UI.play_sound(s)}
                              This played all the sounds simultaneously. Is the behavior the same for everyone?
                                RickW
                                That's what I got...
                                RickW
                                  RickW
                                  Okay, round 2 is closed. TIG and I each got it down to 84 characters with the following code:
                                  @tig said:
                                  c=0;Dir["C:/WINDOWS/Media/*v"].each{|w|UI.play_sound w;UI.inputbox([w],["#{c+=1}"])}
                                  @rickw said:
                                  i=0;Dir["C:/WINDOWS/Media/*v"].each{|f|UI.play_sound f;puts"#{i+=1}: #{f}";sleep(3)}
                                  I could have squeezed it to 83 by removing the space after the : in the puts statement, but decided against it.
                                  Thanks to everyone who worked on this - it was a fun challenge, and we should do another one next month 😄
                                  RickW
                                    RickW
                                    Too late for deadline, but a shorter (77 characters) solution:
                                    i=0;Dir["C:/WINDOWS/Media/*"].each{|f|UI.play_sound f;puts [i+=1,f];sleep(3)}
                                    If anyone can reduce it from here, please post and enlighten us all 😄
                                    RickW
                                    • daikuD Offline
                                      daiku
                                      OBFUSCATORS! You should be trying to make it MORE readable, not less! (switch to high, crackly voice) You young punks don't know how good you've got it! Why, back in my day, all we had was ones and zeros. And sometimes we didn't even have zeros, and we had to use the letter O!
                                      Clark Bremer
                                      http://www.northernlightstimberframing.com
                                        Jim
                                        i=0;Dir["/WINDOWS/Media/*"].map{|f|UI.play_sound f;p i+=1,f;sleep 3}
                                        That would be 68? 😉
                                          RickW
                                          Nice job Jim! 😄
                                          Clark, that was too funny 😆
                                          RickW
                                            Tweaking Jim's..
                                            i=0;Dir["/*/Media/*v"].map{|f|UI.play_sound f;p i+=1,f;sleep 3}
                                            That would be 63... AND it only plays wav files, not falling over on midi's etc... (62 otherwise)
                                            • 1 / 2
