    Ruby Challenge!
    26 Posts 8 Posters 4.4k Views 8 Watching
      Jim
      Does SketchUp need to remain usable while the sounds are playing?
        RickW
        I don't see that as a requirement, but if you want to implement it, you may get extra kudos.
        The song number and title may be indicated anywhere you like, but if you use popup boxes, remember they often 'ding' when they appear, and that sound must not interfere with the track being played.
        RickW
        www.smustard.com
          Jim
          It's the "without interruption from other system sounds or alerts" that's killing me.
            RickW
            Yes, it's definitely a challenge...
            RickW
            www.smustard.com
              RickW
              So far, we have three entries, all with distinct solutions. Only 3 days left to enter...
              RickW
              www.smustard.com
                todd burch
                Well, count me out. Didn't get to it. Next time!
                Todd
                  RickW
                  Okay, here are the results, sorted by order of submission, path-coded for Windows XP:
                  @rickw said:
                  147 characters, 5 semicolons
                  (f=Dir["C;/Windows/Media/*.wav"]).sort!;i=0;t=UI.start_timer(3,true){puts "#{i}; #{f[i]}";UI.play_sound(f[i]);i+=1;UI.stop_timer(t) if i>=f.length}
                  110 characters, 5 semicolons
                  fn=0;d="c;/Windows/Media";Dir.foreach(d){|s| fn+=1;UI.play_sound(File.join(d,s));puts "#{fn}; #{s}";sleep(2)}
                  @tig said:
                  114 characters, 2 semicolons
                  Dir.chdir(d="C;/WINDOWS/Media/");(c=Dir['*.wav']).each{|w|UI.play_sound(d+w);UI.inputbox([w],[c.index(w).to_s],d)}
                  @jim said:
                  258 characters, 18 semicolons
                  @f=Dir["c;/windows/media/*"];def b(i);io=open(i,"rb");io.pos=28;b=io.read(4);io.close;b.unpack("i")[0].to_f;end;def j;t=0;@f.each_with_index{|s,i|;UI.start_timer(t){;Sketchup.set_status_text"#{i+1};#{s}";UI.play_sound(s);};t+=(File.stat(s).size/b(s));};end;j
                  Kudos to Thicket for the shortest code!
                  Honorable mention to TIG for second-shortest by 4 characters.
                  Kudos to Jim for checking the filesize to get the delay time!
                  Kudos to TIG for a really clever way of presenting the track info and avoiding both sound overlaps and system sound intrusion!
                  Now, for the follow-up challenge:
                  Create the jukebox with less than 100 characters! Entries due by noon (GMT-6) on Monday, 6 August 2007. Short challenge, but the hard work's been done 😄
                  RickW
                  www.smustard.com
                    todd burch
                    Here's mine:
                    iTunes
                    What do I win? 😆
                      RickW
                      Good effort, but you didn't use the UI.play_sound(filename) method. 😆
                      I'm also a bit worried if you put your system sounds into iTunes 😉
                      RickW
                      www.smustard.com
                        Jim
                        I was curious about the behavior of UI.play_sound. On my system, window 2000 pro, I wrote the core of the challenge as follows:
                        Dir["c;\winnt\media\*"].each {|s| UI.play_sound(s)}
                        This played all the sounds simultaneously. Is the behavior the same for everyone?
                          RickW
                          That's what I got...
                          RickW
                          www.smustard.com
                            RickW
                            Okay, round 2 is closed. TIG and I each got it down to 84 characters with the following code:
                            @tig said:
                            c=0;Dir["C:/WINDOWS/Media/*v"].each{|w|UI.play_sound w;UI.inputbox([w],["#{c+=1}"])}
                            @rickw said:
                            i=0;Dir["C:/WINDOWS/Media/*v"].each{|f|UI.play_sound f;puts"#{i+=1}: #{f}";sleep(3)}
                            I could have squeezed it to 83 by removing the space after the : in the puts statement, but decided against it.
                            Thanks to everyone who worked on this - it was a fun challenge, and we should do another one next month 😄
                            RickW
                            www.smustard.com
                              RickW
                              Too late for deadline, but a shorter (77 characters) solution:
                              i=0;Dir["C:/WINDOWS/Media/*"].each{|f|UI.play_sound f;puts [i+=1,f];sleep(3)}
                              If anyone can reduce it from here, please post and enlighten us all 😄
                              RickW
                              www.smustard.com
                              • daikuD Offline
                                daiku
                                OBFUSCATORS! You should be trying to make it MORE readable, not less! (switch to high, crackly voice) You young punks don't know how good you've got it! Why, back in my day, all we had was ones and zeros. And sometimes we didn't even have zeros, and we had to use the letter O!
                                Clark Bremer
                                http://www.northernlightstimberframing.com
                                  Jim
                                  i=0;Dir["/WINDOWS/Media/*"].map{|f|UI.play_sound f;p i+=1,f;sleep 3}
                                  That would be 68? 😉
                                    RickW
                                    Nice job Jim! 😄
                                    Clark, that was too funny 😆
                                    RickW
                                    www.smustard.com
                                      Tweaking Jim's..
                                      i=0;Dir["/*/Media/*v"].map{|f|UI.play_sound f;p i+=1,f;sleep 3}
                                      That would be 63... AND it only plays wav files, not falling over on midi's etc... (62 otherwise)
                                        Jim
                                        @tig said:
                                        Tweaking Jim's..
                                        Alright TIG!
                                        A note about using Dir[""]: I didn't specify a file ending because I have files that end in .WAV. These files do not get played because they end in capital letters. The shortest way to get ALL the files was o use *.
                                          RickW
                                          hmm... the last two solutions won't play on my machine.
                                          RickW
                                          www.smustard.com
                                            Jim
                                            Both work for me.
