    First major attempt at a model. (Fixed the link)
    12 Posts 5 Posters 2.8k Views 5 Watching
    • M
      Masta Squidge
      So, I've been lurking here for a little while, and after playing with SU enough to where i know all the shortcut keys and what will be a problem before it becomes one, I'm starting on my first serious project.
      My first house was made for a "City" project on the Playstation forums and can be found here (Please comment this one also):
      http://sketchup.google.com/3dwarehouse/details?mid=e1c19ee20dfea938285663b602a605b9
      My current project is a house I found on the internet, the drawings aren't complete as far as measurements go, so im just making it as close as I can get while changing it to how I like.
      My source can be found here:
      http://www.houseplans.com/plan_details.asp?id=17630
      While my current progress can be found here:
      http://sketchup.google.com/3dwarehouse/details?mid=8643a87ef564d14f285663b602a605b9
      Note that the Red colored area is where the stairs to the second level will be (as you can see on the floor plan) and I have already figured out how many treads there will be based on 6" rise and 10" run. Yes that makes for very shallow steps, I know.
      The open areas leading outside will be filled in with sliding glass doors, and there will be a basement modeled eventually also.
      The walls are 6" thick, though they should be 5" interior to account for a 2x4 and two sheets of drywall. I made them 6" all around to simplify modeling, which I don't think will affect the model's look once finished.
      Hopefully my high school architecture class paid off a bit Laughing
      Finally here is a screenshot of the plan I found, and the model with a section plane at floor level.
      http://www.sketchucation.com/forums/scf/sas/Newbie/sectionplanehouseone.PNG
      • GaieusG
        Masta,
        I found both links (in the WareHouse) pointing to the WIP house you're still working on. It's nice, clean modelling - I hope you won't have any difficulties with it if you keep it this way.
        I also checked your account in the WH and found this model which (from the description field) seems to be the one you meant to refer to with your first link.
        Just some comments, if you don't mind...
        while it is modelled just fine (like the above one), it is extremely huge! I mean 7 megs for a single house like this is really big (sure it can be due to the car and the trees and the materials...) but I have a whole Gothic town with about 6 churches (modelled with ribbed vaultings from inside and window tracery and plants etc) which is still smaller - "file-size-wise" (of course the poly count is so big that it is rather hard to work with the whole model at once).
        As for openings - they are all individual geometry not grouped, no components etc. One way of reducing your file size is to use components for those things that are repeated in your model.
        anyway use grouping (or components eventually) more extensively so that you have better control of the model. Also layers - I found a "Layer 1" that does not seem to contain anything - layers are great to control visibility (but only for that - they will not separate your geometry in SU).
        Finally if you turn monochrome rendering on, you will see that the faces of your building are almost exclusively reversed (blue - that is the back face). No problem seems to be in SU but there can be times when you run into some problems - like with external renderers or placing things in GE - so try to get used to modelling in a way that only front faces (the white ones) are visible.
        Well I sound to be criticizing only but as I started, apart from these little things, it is nice and clean modelling!
        Thanks for sharing!
        • M
          Masta Squidge
          @gaieus said:
          Masta,
          Thanks for sharing!
          Yeah with the first model i had no idea what i was doing, and i have several textures in there which arent exactly optimized for web with photoshop. The reason its so huge is because they are bitmap images, and we all know that .bmp images are too big! Plus, there is probably stuff in there that i would do away with. The hose in the front yard was only a "hey look what i can do" and i realize that could be modeled with 1/10 as many polygons.
          Anyways, thanks for the comments, and the tip about grouping, I didnt know that, and while it would take alot of work to group all the doors that i have in my current model on the first floor, I'll give that a shot with the second floor.
          Thanks!
          • M
            Masta Squidge
            Also, do I group them, or do I make them components? And when they are grouped, would I then just copy and paste or what?
            I dont exactly know how to stash stuff away to be used repeatedly in the model.
            • GaieusG
              Well, as for doors / windows (for they most probably appear more than once in a model) I'd use components for sure.
              For some more info about this see the SU Guide here:
              http://download.sketchup.com/sketchuphelp/gsu6_win/Content/G-Entities/Ent-Component.htm
              • M
                Masta Squidge
                Here it is currently:
                • Jean LemireJ
                  Jean Lemire
                  Hi folks.
                  Keep in mind that 2x4 are actually 1 1/2" x 3 1/2" (at least here in Canada). The total wall thickness will be 4 1/2" if I add two 1/2" drywalls.
                  Just ideas.
                  • M
                    Masta Squidge
                    4 1/2 is right. I just went with 6 so it would all be one nice thickness all the way around. Bear in mind that this is my second model that is bigger than a car and 6 inches makes it easy on doing the measurements in my head. It makes it really simple to take off half a foot (or add half a foot) to layout the rooms. 4 1/2 takes a few seconds of extra thinking ๐Ÿ˜†
                    Plus now ill be able to use the same door components for everything, as im going back through right now and making sure im only using two (left and right side for the knobs)
                    If i manage to find some detailed blueprints for a house I will make sure to have everything from the corner moulding to the wall thickness correct, but for the purpose of this model, I dont think it matters. Once the roof is on you wont notice it.
                    • N
                      not registered yet
                      @jean lemire said:
                      Hi folks.
                      Just ideas.
                      good of you to remind us of the true "2x4" dimensions, Jean.
                      I'd like to add that 5/8" drywall is more commonly used in construction of houses these days (at least around here!). So I prefer to use 4.75" on wall thickness' just to be safe.
                      P: atomb
                      • M
                        Masta Squidge
                        So... Ummm... How the crap am I going to roof this thing?
                        Current model:
                        I daresay this is a rather complicated roofing situation.
                        Oh and feel free to comment on how it looks. Just dont worry about anything thats missing, because i got a list already.
                        Doh! I just noticed the extra line over the doors in the foyer... Stupid me forgot to delete that when i fixed the "roof" over that area.
                        • N
                          Nick W
                          I have found Aidan Chopra's video tutorials very helpful. Check out the roofing ones: http://www.youtube.com/results?search_query=aidan+chopra+roof+sketchup
                          http://www.nrwiesneski.com
                          • M
                            Masta Squidge
                            yeah ive seen them, and hey fellow guy from wisconsin.
                            Its not that often that I find someone online from here.
