    Snap tolerances
    3 Posts 2 Posters 867 Views 2 Watching
      rhankc
      I am working on a window detail model, and I have found no adjustment to snap tolerances.
      I am working at a true 1 1/8" size and my snap is set at 1/8" when I need to place a point at 15/16" the cursor skips between 7/8" & 1". I cant get it to hit; I have my tolerances set to 1/64" for this drawing but it doesnt help. Is there a snap setting somewhere?
      TIA
      Hank
        tomsdesk
        Hank,
        "Window" pulldown menu, "model info" popup, "units" tab: set both precision and snap to 1/16
        Best, Tom.
        2.5D Trees & Shrubs!
          rhankc
          thanks Tom,
          I had initially tried that and didnt get any change,
          I just changed Enable Length Snapping (un-checked) and the restriction to 1/16" is now enabled. Doesn't quite make sense that unchecking makes less snap possible.
          Thanks for your advice
          Hank
