    Having some geometry issues.
    4 Posts 3 Posters 1.0k Views 3 Watching
      LowRes
      I can't figure out how to give these individual rooms all the same height or how in some way to connect the walls to eachother. Also some ramp issues. Check out the file and you'll see what I mean.
      Thanks in advance.
      needHelp.skp
      P: LowRes
        sorgesu
        1. Select the surface and edges of the ramp and copy to clipboard
          2.Using push pull raise the height of the wall on the 2 straight ends to the desired height.
        2. Use push pull to push the surface of the ramp DOWN and infenrece the bottom of the ramp to stop your push pull in line with the bottom edge
        3. use the MOVE tool NOT push/pull to lift the surface of the walls of of the ramp. Make sure you move perfectly in the blue direction. tap the up arrow to lock in blue direction.
        4. Lift the wall straigh up and inference the adjoining wall for the correct height.
        5. paste in place from the clipboard to get your ramp back ( you push pulled it down so the original is not in the same place.
        done.skp
        Susan Sorger
        • N Offline
          not registered yet
          Susan seems to have it down cold but thought it would be hard to walk around in this building with the walls in the way. I just copied and stacked the one wing of your building on itself a couple of times...did an intersect with model and removed the walls..have no idea what you really want but it was fun playing and now you can go for a walk inside.
          Izz
          aabuild.skp
          P: Isaac
          • N Offline
            not registered yet
            I think the toast-shaped room is interesting. :thup:
            (I'm new. Hi! Just got the program a few days ago. Here's the only thing I've done thus far:
            http://i6.photobucket.com/albums/y208/AcousticGod/HDSt2.jpg
            I look forward to getting to know you, and this community. πŸ˜„ )
            P: AcousticGarden
