    Axis setting retain and re-use
    8 Posts 4 Posters 1.8k Views 4 Watching
      rhankc
      I am working on a building that has a 45 degree section, I have to reset the axes as I work my way around. Each time there is the pick red, green etc.
      Is there a ruby or setting that will save an axes setting and allow you to toggle between normal and angled, without doing the axis tool each time?
      Hank
      • boofredlayB Offline
        boofredlay
        Not that I am aware of but that is a great idea.
          lewiswadsworth
          You can save your axis settings with Scenes...if you only want to save an axis, in the scene manager for that Scene leave only that option checked.
          P: Lewis Wadsworth
          col sporcar si trova
            boofredlay
            Well that is cool. Man I wish I thought of that. Thanks Lewis.
              Lewis is always cool, Eric...
              πŸ˜„
                rhankc
                I got it! That sure helps keep the thought process going. My attention span needs all the help it can get these days!
                Thanks Lewis,
                That's very cool 😎
                Hank
                  lewiswadsworth
                  Glad to help. I also have an axis-only scene built into my default SU template...it resets the axis to its start/default location, which is usually quicker than right-clicking on the axis and choosing "Reset" from the options.
                  P: Lewis Wadsworth
                    I should be thinking of scenes + templates more. I always find things out "on the fly" but there must be some common feature(s) which I always use...
