    How do I attach a file
    5 Posts 4 Posters 1.1k Views 4 Watching
    • N Offline
      not registered yet
      I want to show a model I did in SU how do I attach the file?
      Don
      P: bolter
      • KrisidiousK Offline
        Krisidious
        under your post area you'll see the upload attachment.
        the file has to be under like 2 megs, otherwise you should put it in Google 3D warehouse and then link to it.
        By: Kristoff Rand
        • boofredlayB Offline
          boofredlay
          Hello Don. Here are a couple of links that were created as a tutorial on how to attach files and guidelines.
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=40&t=1334
          But the "preferred way" is this:
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=77&t=760
            tomsdesk
            Hey Boo,
            Did I miss an update/upgrade...weren't we moving to everybody posting offsite at su.porta.ca with a link? I notice not many do...?
            Cornfused, Tom.
            2.5D Trees & Shrubs!
              boofredlay
              Tom, you did not miss anything.
              Now that the move has taken place, a solution is in the works that will make use of the SAS; Kelly's server.
