    Balustrade components
    10 Posts 3 Posters 2.0k Views 3 Watching
    • CadFatherC
      CadFather
      i can't get the balustrade components to show up in the dialog box
      Didier didn't actually mention where the components are picked up from...
      so it's either supersimple and i should just go to bed or grateful if anyone has had some success with this and could let me know...thanks
      • Didier BurD
        Didier Bur
        Components are picked up from your model. They must be part of it, that's-to-say visible in the "In model" tab of the components browser.
        Regards,
        DB
        • CadFatherC
          CadFather
          thanks Didier...as always! 😄
          • rodrigonotorR
            rodrigonotor
            Hi Didier, I select 2 lines but nothing happen. When no line selected the dialog error appears: "No selection. Select Lines please".
            I use balustrade whit components. What I am doing wrong?
            Thanks in advance.
            • Sketchando.net • www.arqcad.net •
            • Didier BurD
              Didier Bur
              If you select 2 lines (or 1 or more, but not guide lines) it MUST work.
              Perhaps you didn't understand that once lines are selected, you have to select the command "Balustrade with components" from the Plugins menu ?
              I tested it one minute ago on SU6 and it works, so what else can I say ?
              DB
              • rodrigonotorR
                rodrigonotor
                Thanks Didier, 2 lines different elevation?
                • CadFatherC
                  CadFather
                  Hi Didier, sometimes i get strange results, especially the balustrade part - it is either offset at some distance (even with straight lines, or more often if the shape is curvy, as below
                  used default settings (cm)
                  • Didier BurD
                    Didier Bur
                    No, 2 connected lines, think of it as the path for handrail and balusters.
                    @CadFather: 😳 😳 I must look into that. Are your base lines part of a group ?
                    DB
                    • CadFatherC
                      CadFather
                      Hi Didier, no it was just an arc and 2 lines - but it did happen even with straight lines on occasion
                      i just double checked i have the latest version 😕
                      oops forgot the important bit! i draw 2 lines and an arc (see pic: creating the objects in different sequences gives different results) > run balustrade and get the weird offset
                      now the even more strange bit: make a copy of the edges > run balustrade > it works! 😕 😲
                      bc.skp
                      • rodrigonotorR
                        rodrigonotor
                        Work now!
                        I think maybe a old version of balustrade.rb is installed in my plugins folder, erase and install balustrade_components.rb and work fine, more later I will try a test whit the component option.
                        Thank you for this great plugin.
                        Saludos
