    Filling gaps in a terrain
    26 Posts 5 Posters 8.3k Views 5 Watching
    • EdsonE
      Edson
      @gaieus said:
      Edson, I restitched the terrain. Is this what you wanted?
      yes! thank you very much.
      could you please tell me how you did it? like they say, better than giving the fish away is teaching how to get it from the sea.
      cheers.
      edson
      http://www.mahfuz.arq.br
      • GaieusG
        Simply hand-stitched. Tried to follow the dotted (smoothed) lines where possible to regain the original terrain - at some places I had to "improvise" though.
        • EdsonE
          Edson
          this thread was very, very helpful. you guys opened my eyes to a number of features that i was not aware of. i had a look at the manual just to make sure i got the whole picture. thank you all.
          • S
            sorgesu
            okay, I found out what is happening with the zero offset. When I type in the zero, SketchUp appears to accept it, except if you zoom in on the selected offset, it is clear that it is not behaving as if it were zero. In fact it appears to create an offset of 1 despite the fact that the VCB shows 0.
            If I type in .001 that is accepted and the offset might as well be zero.
            Dylan, I wonder if you could test this on your machine. Is that the result that you were really getting?
            Susan Sorger
            • D
              dylan
              Hi Susan,
              Well I tried this test a little more closely and you are correct, you cannot use 0.
              If I use zero, it does work, but to a default of 25mm. On a large drawing you probably would not see this but close up you can.
              If I type in 0.001 as you suggested then it will not work, but 0.1 does.
              So if I wish to have a zero offset in the future, then 0.1 it will be - a tenth of a millimetre is good enough for me
              πŸ˜„
              http://dmdarchitecture.co.uk/
              • EdsonE
                Edson
                i had the same problem. while trying the zero offset, it kept returning to the default value. as soon as i put something more than zero it worked.
                • 2 / 2
