    Crossing the Intersection...
    3 Posts 3 Posters 1.2k Views 3 Watching
    • N
      not registered yet
      Hi all,
      I tried to RTFM but didn't find the answer to my problem. I am modelling my house and thought that a good way to do it would be to build boxes for the different sections that have different rooflines and then push them together. It works fine except that where two boxes push together and share a wall, I still see the intersecting lines. Is there some sort of merge function that I don't see???
      also, is there a better way to do this than to divide up the house as i have done?
      P: Lou_Zeur
      • KrisidiousK
        Krisidious
        before you push pull them together....
        select each box all of it... and then right click and select make group...
        now open each group to edit it... and then the walls will not stick together...
        I could go into this further... but go to my tutorial on the TUT section of this website and look for how a pro builds a house in SU
        By: Kristoff Rand
        • D
          dylan
          Lou if it's the line where the groups meet which you are talking about then do the following.
          Open the group.
          Highlight the line, right click, hide.
          Then do the same with the group which has the other line showing.
          Although it looks like one line, you need to hide the line in each group.
          Dylan
          http://dmdarchitecture.co.uk/
